Viewsonic VE710b
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Viewsonic VE710b
    Another thing....
    Always use 105C temp rated caps.
    Given the same conditions they last much longer than 85C caps.
    Mann-Made Global Warming.
    - Dr Seuss
    • junktv
      • Nov 2010
      • 3065
      Ok thanks so basically as long as the ripple rate is higher then you're good.
      Also the ceramic fuse says LF. T.2.5AH250V and is 5x20mm. I finally found them hidden under the odd 5.1 and 5.2 sizes. I'm guessing these are fast burn or are they slow?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        That one took some looking. Their site isn't laid out so well.
        LF = Littlefuse [the company]
        T = Time Lag [Slo Blo]
        2.5A = the amps
        H = Ceramic
        250V = the volts [obviously]
        https://cdn.badcaps-static.com/pdfs/...b5714cc585.pdf
        - Dr Seuss
        • junktv
          • Nov 2010
          • 3065
          Link saved. I was figureing the little F may have ment fast. This electronics stuff confuses me. So much stuff to learn. I really thank you and the others for taking the time to help people like me.
          • mockingbird
            • Dec 2008
            • 5488
            #45
            This is the exact fuse that the screen uses. You don't really need to change it:
            http://www.newark.com/jsp/search/pro...sp?sku=42K9311
            • junktv
              • Nov 2010
              • 3065
              Ya i figure might aswell grab one though so added it and a couple others. They one in mine was good also and the monitor powered up but going to wait untill i get the correct 470uf 25v cap to see if it really works..
              http://search.digikey.com/scripts/Dk...55255665369341
              • mockingbird
                • Dec 2008
                • 5488
                #47
                I've been using it for a few days now. Good colors, wish it was a little brighter though. All in all, definitely worth the effort saving it from the curb and the few dollars worth of caps. When I first turned it on, everything was a bit yellow, I had to muck around with the settings a bit and then auto adjusted it.
                • junktv
                  • Nov 2010
                  • 3065
                  Mine would always auto adjust if you hit the button or not lol. The starting was a good sign so i have faith it will work. My main monitor is a dell 1800 something but i remember the viewsonic being way different. Right now i'm running a windows pc on avi and a linux box through vga on this dell and i can't wait to get back to dual monitors.
                  It's definitely worth it. It's just hard for people who don't know how to. I'd much rather see something reused or fixed than to end up on a trash pile or recycled for no real need. Waste not want not
                  • junktv
                    • Nov 2010
                    • 3065
                    The other cap arrived and i soldered it in yesterday. After assembling the monitor i plugged it in and it came on then hit power unplugged it and hooked it to a PC but it wouldn't coem on. I took the monitor back apart and i couldn't see anything wrong so tried again and still won't power up. Any ideas? The fuse is good and i don't see any picos.
                    Could i have got a bad cap? http://search.digikey.com/scripts/Dk...name=P12388-ND
                    The closest other cap i could try would be a http://search.digikey.com/scripts/Dk...ds=565-1694-nd
                    On another note a pico fixed the dell 153fpb i had that was broke.
                    • seanc
                      • Nov 2008
                      • 1319
                      #50
                      So have you replaced all of the capacitors now?
                      Does the monitor power up with thre VGA cable disconnected from a PC?
                      As for the Dell, I hope you resoldered the transformers for the inverter.
                      • junktv
                        • Nov 2010
                        • 3065
                        No I just replaced these.
                        3x 470uf 16v 8x12mm MCZ
                        1500uf 16v 13x17mm MCZ
                        470uf 25v 10x12mm FM
                        1000uf 10v 8x15mm MCZ
                        Nope and have even tried another power cable. It powered up with the zl in it and powered up with this one on the bench so not sure what went wrong from then to carrying it into another room. Even before i remember the power led coming on now nothing.
                        If these ceramic fuses are blown do they still show continuity?
                        On the dell ,yes i did plus some other spots that looked bad.
                        • seanc
                          • Nov 2008
                          • 1319
                          #52
                          Check that none of the boards are shorting out on the metal frame, double check your solder joints.
                          • junktv
                            • Nov 2010
                            • 3065
                            I'm sure nothing is grounding other than what should be. There is plenty of clearance. I did notice some rings on the power plug but i think those are just mounting supports. I'm going to hit them after dinner ,put in new fuse and may try the CC KZE 470uf 35v. It's higher voltage but close on the specs at 23mohm 1.82a.
                            • mockingbird
                              • Dec 2008
                              • 5488
                              #54
                              Take some pictures of the board front and back and post them here.
                              Also, if you were anyways ordering a different cap, you should have ordered something other than MCZ. Next time, post a list of the caps and their series, and then it can be cross-referenced to see what's a good replacement.
                              • junktv
                                • Nov 2010
                                • 3065
                                See page 2. Remember i already had the mcz.
                                Will try to get some better pics though.
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #56
                                  Those are before the recap though.
                                  You really should have used the proper series. You would have avoided this.
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    Na the MCZ where the recap. I just used a ZL originally for the 470uf 25v which wasn't up to the spec that the bad EB's i was replacing were so i replaced it for the FM ya'll recomended.
                                    https://www.badcaps.net/forum/showpo...2&postcount=34
                                    https://www.badcaps.net/forum/showpo...2&postcount=32
                                    It will be tomorrow before pics. i'm going to try an idea with stitching a few together so they aren't rubbish.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      Just some clarification questions here. Assuming you have a computer hooked up to the LCD ...
                                      1) Does the power LED come on and stay green?
                                      2) Can you see the display if you shine a flashlight?
                                      Depending on how you answer 1 and 2, we will need readings from your multimeter.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        No led at all now.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #60
                                          No led at all now.
                                          Okay, let's start by verifying a few voltages.
                                          Carefully (high voltage alert) measure the DC voltage across the main filter capacitor (the big one).
                                          If you are in the USA, it should read 160V to 165V DC.
                                          Next, check the voltages at the multicolored connector on the power board. At least one of them should be a steady 5V DC. The 5V DC is what provides power to the logic board. If the logic board is not getting 5V DC, the power LED will never come on.
                                          You should see at least one other voltage on the connector. Perhaps 12V or 19V DC. The other pins are GND and probably BL/ON.
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • StefanNg
                                            Viewsonic VX2718-PC-mhd SG2701B01-8
                                            by StefanNg
                                            Hi, Badcaps.
                                            I am troubleshooting a monitor
                                            Viewsonic VX2718-PC-mhd.
                                            Panel model SG2701BSG2701-8
                                            Symptoms is no image.
                                            This panel has 2 panel board connected by a U-ribbon.
                                            When I disconnected the ribbon, I get a perfect half screen image.
                                            I took some test point voltage, when ribbon disconnected.
                                            HVAA 8.38v
                                            FVDD12 1.21v
                                            FDD33 3.3v
                                            VIN 11.79v
                                            VAA 16.85v
                                            VGHF 30.16v
                                            VGL -8.02v
                                            CK1_I ~ CK8_I 1.403v
                                            CK1_L ~ CK8_L 8.26v
                                            When I connect both panel board
                                            HVAA, VGHF, and CKx_L...
                                            05-17-2025, 01:43 AM
                                          • Fagauthier
                                            Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                                            by Fagauthier
                                            I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                                            Model #EADP-64BF B
                                            The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                                            07-08-2023, 08:02 PM
                                          • Returning Buick
                                            Viewsonic G810 vertical deflection problem
                                            by Returning Buick
                                            I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                                            04-01-2025, 07:57 PM
                                          • RetroComputingGrotto
                                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                            by RetroComputingGrotto
                                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                            What component(s)...
                                            02-03-2025, 06:00 AM
