Acer ED270R no display/black screen, backlight is on and Win11 recognizes
  • C:\
    • Sep 2023
    • 5
    Hello all, first post here as a newcomer to the industry, trying to repair and flip some bad monitors. I have successfully repaired a couple bad IC LG monitors and car electronics so I know enough to be dangerous but some concepts are still unbeknownst to me, so bear with me. I have 2 Acer ED270R's with the same problem, and one good Ed270R with a cracked screen but functions normally as a tester/donor.
    The issue:
    These monitors will both power on and illuminate the backlight but will not display an image, including the splash screen. If you plug the unit into a computer on any port it will react and stayed powered on with a good backlight continuously as well as be visible and usable in Windows. Changing settings like res/Hz will cause the display to power off briefly like normal behavior. Yet there is never an image.
    Some searching only shows that this is a frequent issue with these monitors but I can find absolutely nothing about repair attempts or service manuals. Swapping the power boards from the good unit yields the same results, so my guess is it's an issue on the tcon/video driver board that attached to the LCD via 4 soldered on ribbon cables. No swapping that board since you can't swap those ribbons. Where to start here? Bad caps? Bad firmware? Check for shorts? Thanks for any and all input.
  • C:\
    • Sep 2023
    • 5
    Re: Acer ED270R no display/black screen, backlight is on and Win11 recognizes
    Best guess currently is bad caps on the tcon (I think?) board connected to the lcd. Going to get an ESR meter and start checking them in circuit.
    • eenee
      • Aug 2022
      • 48
      • Mongolia
      Hey did you find any solution for this? I'm having the same issue
      • eenee
        • Aug 2022
        • 48
        • Mongolia
        Nevermind, after opening it up i found that F1 was blown with no short circuits. I replaced the fuse and it's working good currently
          Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) Spin 512 Specification for Upgrade or Repair
          This specification for the Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB boardview and 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
          09-06-2024, 04:40 PM
        • DaniK
          Acer Aspire E5-574-52RH - black screen
          by DaniK
          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
          Symptoms are:
          - random black screen after displaying Acer logo...
          02-21-2024, 06:27 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • amennone
          Acer A315-24p-r2km , black screen. Bios
          by amennone
          Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
          As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
          With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
          07-31-2025, 04:19 PM
        • rybby
          Acer Aspire 5 A515-51 power on but black screen
          by rybby
          I have an acer aspire 5 a515-51 that turns on but has a black screen.
          This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
          Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
          06-16-2023, 09:41 AM
