Optiquest Q9
  • hdanner
    • Oct 2010
    Optiquest Q9
    My Optiquest Q9 monitor muted the sound. By luck I was able to get the Turn on and turn off box. I still do not know what buttons to push to get this box again. Can someone help?
    hdanner@msn.com
  • cheeky2
    Help with identifying missing resistor from JVC push buttons TV3024-ZC10-01(C)
    by cheeky2
    Someone previously had damaged a couple of the push buttons who has whilst pushing them in pushed off a smd resistor from a JVC 40" LED TV LT-40C550 main board MSDV3255-ZC01.
    The missing resistor off the push control buttons TV3024-ZC10-01(C) pcb is R06 see the pictures.
    I have tried downloading manuals for the Haier manufactured main board however they don't include the schematic for the push buttons!
    So if anyone has the pcb that could measure the resistance or have a schematic diagram for it would be much appreciated.
    Thanks ...
    01-20-2022, 01:35 PM
  • x_orange90_x
    Seven Leagues Slot Machine stop button issues
    by x_orange90_x
    I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
    The issue now is the Stop buttons are intermittently...
    02-12-2025, 10:01 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • tbsmith
    Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
    by tbsmith
    I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
    07-12-2025, 11:40 AM
  • LEEDASH
    Aiwa TX-110 Tuner Buttons
    by LEEDASH
    Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
    Thank you
    05-07-2024, 02:41 PM
