Gaurdall G-LCD19B
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: Gaurdall G-LCD19B
    Well the parts arrived fitted and still showing 1.95v.
    Just debating with myself whether the caps could be doing this as i seem to be getting voltage readings off the top of the caps (not sure if this is usual never done it before ).
    • seanc
      • Nov 2008
      • 1319
      Ahah, you now have a location showing - you're somewhere near me
      So yes, the caps could be causing this problem.
      I had a 17" monitor with external 12v PSU, the monitor had gradually taken longer and longer to turn on, then wouldn't turn on at all.
      Investigated the PSU - putting out 12v as expected, tested with another just in case - still dead.
      Tested ESR of the small 100uf 16v caps, starting nearest the power jack - very high ESR.
      There were about 3 caps in parallel there, I changed those 3.
      Worked fine afterward
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Hi see you were near
        well think i might change them all got nothing to lose, but will hold off till tomorrow see if can find anything else with a bit of prodding about.
        Not holding out much hope as i think apart from caps have been thro everything apart from the chips
        • seanc
          • Nov 2008
          • 1319
          Measure the voltage going across the cap above the VGA connector.
          • sabre504
            • May 2010
            • 449
            • United Kingdom
            Volts across legs 12.23
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              #26
              Should have said
              all bigger caps are 16v 100uf
              3 small caps 16v 10uf
              • seanc
                • Nov 2008
                • 1319
                #27
                Tried the caps above that, to the left and right of some sort of black component?
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  #28
                  Thats a volt reg getting 4.99 on the 5v side and 3.3 on the other
                  • seanc
                    • Nov 2008
                    • 1319
                    #29
                    All sounds OK to me!
                    • sabre504
                      • May 2010
                      • 449
                      • United Kingdom
                      #30
                      Yes all the volts appear right until you get to 1.8 regs.
                      So as i say try a change of caps start with the 16v 10uf.
                      Mind you am eyeing up the guts of my Xerox 19" wondering if i could rig them up in the casing if all else fails
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • Yanleb
                        LG 60PK550 Logic Control Board EBR63450301
                        by Yanleb
                        Hi all, I just want to share the repair of my 60PK550-UA TV set.
                        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                        C57: 3.30V
                        C61:...
                        07-20-2023, 12:38 AM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • sfernandes
                        Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
                        by sfernandes
                        Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
                        What I have done to try to isolate the issue so far:
                        The system powers on and stays on with...
                        01-23-2023, 06:03 PM
