Gaurdall G-LCD19B
+ More Options
Latest Activity
  • sabre504
    replied
    Re: Gaurdall G-LCD19B
    Right better pic now
  • sabre504
    replied
    I have tried 2 seperate power supplies and get the same result.
    I know i need better picture will do that tomorrow and will post
    I tried the LCD panel in my Xerox unit as this has no screen but comes in handy for testing ,
    but i dont have another of these boards cant even find one online it has no makers name or code just VA-3700 VER:1.1 and it is a single sided board there are no components on the back .
    But have found the monitor its a professional IT and security monitor (bit of a mix) has 1 vga 2x s vid 2x bnc i think they are called and has a hard glass front quite a nice unit in all
  • PlainBill
    replied
    I'm assuming you have verified the external power supply is good. If so, a better picture is a good idea. I can identify two voltage regulators, and there is at least one and possibly two more candidates. verifying they are working would be the next order of business.
    PlainBill
  • jetadm123
    replied
    You say you took out lcd panel and it tested good on another monitor. Was that monitor also the same model as the one in question? If yes, have you tried swapping the logic/video card from the "good" monitor to see whether or not the card is the problem?
  • sabre504
    replied
    Have checked the wires and they are working (have continuity from one end to the other s assume its ok
  • seanc
    replied
    Have you ruled out the cable connecting the LCD to the main board?
  • sabre504
    replied
    Just a quick pic till i get better one
  • sabre504
    replied
    The monitor shows only white screen but as i said that tested ok on another unit.
    The switches do nothing when connected but all the pins where the switch panel connects show voltage except the earth pin so the inverter runs constantly it is possible that someone has put in a new inverter board and not wired it correctly.
    Have checked voltages on other parts to see if supply is going in and out but these have been checked against data sheets for the individual parts and not data sheet for the board.
    I will post a pic of the whole set up when i get camera working
  • pedro
    replied
    Originally posted by sabre504
    HI have a problem with this unit .
    And I'm sure that you'll eventually tell us what it is, but in the description you posted I can't detect one.
    Not sure if its a caps problem but thought someone may have a clue as to the problem.
    Firstly when power is applied (12v 4a) the screen lights up so inverter working ok .
    Took out lcd panel and tested on another unit and it works fine .
    So there's no problem there ....
    Disconnected the control switch panel and it still powers up so something is amiss on the control board.
    Why do you presume this. Many many monitors power up in the "ON" state without user intervention. With the front control panel disconnected, I'd expect it to "get up and go" normally.
    Looked online but cannot find a data sheet for the board so just wondered if anyone had come across this board (VA-3700 VER:1.1) or a similar problem before.
    Have uploaded a pic just so you can see it not a good one need batteries for camera had to use phone.
    Any help or input appreciated
    Pictures may help, but so far I'm in the dark as to what isn't behaving properly.
  • sabre504
    started a topic Gaurdall G-LCD19B
    Gaurdall G-LCD19B
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • sfernandes
    Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
    by sfernandes
    Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
    What I have done to try to isolate the issue so far:
    The system powers on and stays on with...
    01-23-2023, 06:03 PM
    Linear Garage Door Opener Control board took a crap install a new control board back normal
    by sam_sam_sam
    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
    02-08-2025, 06:52 AM
