H.P. L1710 back lamps turning off
  • alexanna
    • Mar 2010
    • 1346
    Re: H.P. L1710 back lamps turning off
    I wonder if my problem may be trying to use a voltage regulator that has been salvaged from another board, I just replaced the 1117 3.3v regulator with a used one and I get a good green power light for about 5 or 6 seconds with a good 3.3v and the it turns amber, back lights are still staying on but the v out of the 3.3v regulator goes down to 1.6 volts ,It is also very Hot to the touch.If the regulator states it's 3.3v I am guessing a resistor is not involved?
    Al.
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by alexanna
      I realy think it is a oz5936gn,I will get my wife to help verify
      she has better eyes than I do.Thanks for the effort but this damm thing has devloped some other issues.I will try to explain in my next post.
      Al
      Except that OZ5936 is not a legitimate part number. Even the surplus IC sellers don't claim to have it on hand.
      PlainBill
      • PlainBill
        • Feb 2009
        • 7034
        Al.
        Yes.
        PlainBill
        • alexanna
          • Mar 2010
          • 1346
          Yes.
          PlainBill
          Using the used part, or no resistor?
          Al.
          • PlainBill
            • Feb 2009
            • 7034
            Al.
            No, the used part was not the problem. Yes, there is no resistor.
            PlainBill
            • alexanna
              • Mar 2010
              • 1346
              #26
              Well it's time to call it quits on this one.
              For some reason on the 3.3v regulator pads the ground pad has become shorted to the v out pad, I guess that explains the hot to the touch and failing regulator. I cannot see anything thing obvious on the surface of the logic board and it's only the 3.3v regulator that shows shorted to ground, the 1.8v pads are ok.
              Al.
              • micoman
                • Mar 2012
                dear friend. I have 3 x monitors LCD HP L1710, I want clean inside because drop water, but I canΒ΄t remove the back cover. I remove four screws. But How I remove the back cover to access inside the monitor.??
                Thanks for your help
                I have a H.P. L 1740 that after about 20 minutes the back lights are going off, And a image is visible.
                The B.L. on signal is not changing when the lamps go off, I have traced the signal down to the green card between the two ccfl transformers and it is good.
                With the monitor dissembled it takes much longer for the lamps to turn off upwards of 2 hours or more.
                I am seeing 12.5v across the inverter caps when the lamps or on and aprox.13v when the lamps are not on.
                I have measured the A.C. voltage on the return lines of the ccfls when the lamps are on.
                #3 is between 1.18 and 1.25 vac as measured with min. max
                #4 is 1.42 to 1.58 vac
                #1 is 1.70 to 1.89 vac
                And #2 is 1.14 to 1.20 vac
                I have tried the measurements with two different panels and voltages are very similar on the return lines.I really haven't checked voltages on the return lines enough to know if there is too much of a difference in the voltages on the return lines? I am thinking about poor solder joints in the inverter area. When I can get this to fail again is there anything else that I could check to narrow down the problem?
                U1 is an oz59360n. The two other 8 leg chips are 9971gm mosfets.
                Al.
                • alexanna
                  • Mar 2010
                  • 1346
                  #28
                  Remove the front cover first.The LCD and it's and power supply are cliped to the back cover.You would have to pry it out.
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 08:10 PM
