MSI PS341WU monitor update failed.
  • sarkun
    • May 2023
    • 4
    • 日本
    I need help, FW update of my MSI PS341WU monitor failed and will not power on.
    I have read the BIOS directly from the EEPROM after the failure, I attach it with the Bin file.
    I need the Bios file.
    • 20637
    Re: MSI PS341WU monitor update failed.
    https://www.msi.com/Content-Creation...pport#firmware
    • sarkun
      • May 2023
      • 4
      • 日本
      I'm sorry, I didn't have enough information, but I couldn't transfer the Bin file downloadable from MSI directly to the EEPROM.
        • 20637
        ok try this one
        • sarkun
          • May 2023
          • 4
          • 日本
          Transferred to EEPROM, no change. Are the others broken too
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
          • test.it
            Failed bios update on a Dell Precision 3650 Tower
            by test.it
            Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
            01-28-2025, 07:32 PM
          • alegatorul
            Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
            by alegatorul
            hi,
            i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
            Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
            I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
            11-03-2024, 02:28 AM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
