Do KVM boxes get flaky, or is the problem described below a display issue?
The Viewsonic VX922 in my office attaches to a Cables to Go 4 port KVM switch, model 35555, like this one:
http://www.cablestogo.com/product.as...507&sku=35555#
For the last couple of weeks I have been building PCs and so switching back and forth between the four positions on the KVM frequently. Lately in the morning when I turn everything on for the first time the Viewsonic acts like it is seeing a video signal that it cannot handle. (Nothing on the screen, but not the "no signal" message.) It isn't the two seconds to black sort of problem. The thing is, so far, whenever I get fed up and plug the display directly into the PC it works, which would tend to indicate a KVM problem, but then when I move the display back to the KVM video out jack, and plug one of the 4 KVM video cables into the PC, the display still works! Once everything is warmed up, there are no problems. Or maybe once it has ever worked, there are no problems (which might indicate a driver issue on the graphics card, some of them won't start if they don't see a proper display device). So the results so far are not very clear, as to where the problem lies, other than at least part of it seems to be a warm up issue somewhere.
The only other symptom I have noticed is that, when hooked up to the KVM, the monitor doesn't always sync up in time to show the BIOS screen. Again, that could be the KVM or the Display.
Tomorrow I will try to remember to cold start the Viewsonic plugged straight into the PC, if that doesn't work then it is the monitor. If it does, it might be the KVM...
Yeah, I know, time to open up the KVM and see if there are signs of trouble inside. Hopefully the fault isn't in the Viewsonic, since my only other options are a couple of small 17" LCDs or one of the spare humongous CRT displays.
