Dell E177FPb LCD monitor
  • Wizard53
    • Sep 2010
    I have a Dell E177FPb LCD monitor that is dead. I suspect it is the power supply board, do not see any swollen or leaking caps. Any Ideas ?
    Does anyone have a schematic or trouble shooting / repair guide ?
    Craig
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E177FPb LCD monitor
    If this is a Benq board, it is likely that the picofuse, c5707 transistors, and/or fu9024 are bad.
    Search for c5707 on this forum as there is a ton of details on how to fix this board (including resoldering the transformers).
    Also, Post clear focused pictures of your boards after reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    --- begin sig file ---
    --- end sig file ---
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
