SyncMaster 920 - Flashing blue led, power cycling, swollen cap in PSU
  • Heywire
    • Sep 2010
    • 10
    Hello Everyone... I've spent the last couple of days absorbing the wealth of knowledge on this board -- THANKS!
    I have a Samsung SyncMaster 920 19" widescreen LCD monitor that has recently started having troubles starting. When I apply power (with a VGA cable attached to the PC), the blue light comes on, I hear something in the power supply making a bit of noise, then it turns off. It seems to be about a 2 second cycle. I've been able to get it to start a handful of times, and it works fine once it is started.
    Note: If I remove the LCD ribbon, I can get the monitor to power on each time, and respond properly (obviously with an all-white screen).
    So I started digging around and I found that there is a swollen Samxon GK 1000uF 10v cap on the board. I would like to recap the PSU and the control board, but I'm having a bit of trouble matching up the proper replacement parts (ESR/ripple/etc). I was hoping someone could point me in the right direction on which series replacements I should use. My electronics knowledge is a little rusty, but from what I've been reading, ripple current needs to be equal or higher. Its mostly ESR I'm having trouble comparing. Do I just compare the impedance, or is there more to it?
    Here are the caps I'd like to replace (information was collected from the various data sheets):
    Code:
    Component	Value	Voltage	Model/Series	Brand	Ripple Current	Dimensions	Temp
    C820, 821, 826	47uF	25v	SH		Su'scon	110mA		8x12mm		125°
    C501, 817	470uF	25v	RZD		Lelon	1144mA		10x16mm		105°
    C818*		1000uF	10v	GK		Samxon	1430mA		10x16mm		105°
    C815		1000uF	25v	RZD		Lelon	1888mA		12.5x20mm	105°
    C119		100uF	16v	KM		Samxon	125mA		5x11mm		105°
    C124		220uF	10v	RGA		Lelon	175mA		6.3x11mm	105°
    C127, 133, 141	22uF	16v	SK		Su'scon	63mA		5x11mm		105°
    Thanks in advance!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: SyncMaster 920 - Flashing blue led, power cycling, swollen cap in PSU
    That 1000uF 10V cap is providing the 5V DC to the logic board. If it is bad, that would explain why the logic board isn't working and thus no picture.
    Here is the link I refer people to
    https://www.badcaps.net/forum/showpo...47&postcount=3
    edit: a couple more links
    https://www.badcaps.net/forum/showpo...68&postcount=5
    https://www.badcaps.net/forum/showthread.php?t=10764
    edit2:
    If you find that Panasonic FC or FM series is suitable (it probably is), see PlainBill's instructions on how to order
    https://www.badcaps.net/forum/showpo...33&postcount=2
    Last edited by retiredcaps; 09-08-2010, 05:36 PM. Reason: more links explaining caps esr, impedance, ripple, etc
    --- begin sig file ---
    --- end sig file ---
    • Heywire
      • Sep 2010
      • 10
      Thanks very much for the links. The last two I had seen already I think I'm ready to start picking some caps, starting with the Panasonic FM/FC series, if they have matches...
      Thanks again!
      • Heywire
        • Sep 2010
        • 10
        Here is the parts list I'm looking at (in the same order of the parts in my previous post). All in stock at Digi-Key, less than $5 for all parts. If anyone notices something wrong/bad, please let me know...
        Note: The first component is originally a 125 degree piece -- I can't imagine that 125 would be necessary, but please correct me if I am wrong...
        Thanks again!
        Code:
        Model	Brand		Ripple	Imped	Dimensions	Temp	Part No
        FM	Panasonic	280mA	0.3	5x11mm		105	EEUFM1E470
        FM	Panasonic	1790mA	0.026	10x16mm		105	EEUFM1E471
        FM	Panasonic	1790mA	0.026	10x16mm		105	EEUFM1A102
        FM	Panasonic	2600mA	0.018	12.5x20mm	105	EEUFM1E102
        FC	Panasonic	290mA	0.35	6.3x11.2	105	EEUFC1C101
        FM	Panasonic	455mA	0.13	6.3x11.2	105	EEUFM1A221
        KG	Panasonic	70mA	-	5x7mm		105	ECEA1CKG220
        • retiredcaps
          • Apr 2010
          • 9271
          Code:
          Would suggest this
          http://search.digikey.com/scripts/Dk...name=P11213-ND
          for the 22uF 16V cap. This one is 22uF 25V and it will work fine. It is a FC series cap.
          edit: If you want ALL FM series, go with this
          http://search.digikey.com/scripts/Dk...s=100uf+25v+fm
          for your 100uF 16V cap. Again, it is 100uF 25V, but it will work fine.
          • Heywire
            • Sep 2010
            • 10
            Ok, well somehow I missed that Digikey does not carry the EEUFM1A221, so I went to an EEU-FC1A221S.
            Thanks for all of your help retiredcaps! Hopefully I'll have some good news to report sometime next week!
            • Heywire
              • Sep 2010
              • 10
              Update!
              The monitor is working great! Thanks for all of your help, retiredcaps! And thanks to everyone else for building up a wealth of knowledge at this site.
              Again, thanks!
              • retiredcaps
                • Apr 2010
                • 9271
                Good to hear it was just the caps and not something with the logic board. You should get another good 5+ years of use out of the monitor with the new caps.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Update!
                  Again, thanks!
                  Nice ....another one saved from the landfill
                  • ASUS ROG Maximus IX Code
                  • Intel Core i5-7600K 3.8GHz
                  • Windows 10 Pro x64
                  • GeForce GT1050
                  • liranics
                    • Jun 2011
                    Update!
                    Again, thanks!
                    hey Heywire.
                    i have same problem, how do solve the problem , what is the part as you replaced ?
                    • Heywire
                      • Sep 2010
                      • 10
                      Originally posted by liranics
                      hey Heywire.
                      My parts list is above, in post #4. I replaced all of those parts listed.
                      • STKR123
                        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                        by STKR123
                        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                        I wonder if re-flashing the BIOS might be of any use here.
                        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                        11-03-2024, 06:58 AM
                      • high-tech
                        Samsung UN55F7050AFXZA ver. TD01 power cycling
                        by high-tech
                        Hello everybody, I could use some help on this one... It's got me guessing...
                        I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                        (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                        (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                        (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                        (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                        9. ground (PWM2) 10. 0.9 volts cycling...
                        09-15-2020, 03:39 PM
                        Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-07-2024, 05:50 AM
                        Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                        09-07-2024, 05:00 AM
                        Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
