Acer AL2216W Dead
  • a55bruce
    • Aug 2010
    • 26
    Acer AL2216W Dead
    I have a dead (no light) Acer AL2216W with a DAC-19M009 power supply. I changed out the capacitors (still dead). I found 4 fuses (F100,F101,F102,F200) that check good. The big 120uF cap has 143VDC across it. What's next?
    Thanks for the help.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acer AL2216W Dead
    143V DC is low. It should be 1.4* mains. Even at 110V mains, that is 110 * 1.4 = 154V DC. Is it at steady 143V DC?
    Do you have secondary voltages like 5V DC on the connector to the logic card?
    --- begin sig file ---
    --- end sig file ---
    • a55bruce
      • Aug 2010
      • 26
      My mistake, re-measured the cap, it's at 166VDC. There are no voltages present at the connector to the logic board
      • retiredcaps
        • Apr 2010
        • 9271
        1) Interesting. This is the 3rd no secondary voltage case to arrive in the last 2 days. AND this board looks like my non working CMV monitor as well.
        2) When you say the fuses are good, do you mean they measure around 0.3 ohms?
        3) Is that 8 pin IC in the upper right hand corner (2nd picture - backside) part number LM358 (that is what mine is)?
        • a55bruce
          • Aug 2010
          • 26
          2) The fuses do measure around 0.3 ohms.
          3) The 8 pin IC is a LM393.
          • retiredcaps
            • Apr 2010
            • 9271
            My bad, I meant upper backside upper left corner near the AC plug. Mine is EA1532A which is a SMPS controller IC.
            • a55bruce
              • Aug 2010
              • 26
              Wow!
              That is some hard to read lettering, badly faded. But, it looks like it says EA ?532A. I would think it's the same as yours.
              • retiredcaps
                • Apr 2010
                • 9271
                Wow!
                1) Okay, it sounds like you have the same SMPS controller.
                2) The datasheet for it is at
                http://pdf1.alldatasheet.com/datashe.../TEA1532T.html
                Download and look at the pinouts and page 5 figure 4 (typical applications).
                3) Your problem might be the same as this thread going on right now at
                https://www.badcaps.net/forum/showthread.php?t=9756
                Start with post #6. Pay special attention to post #30 by PlainBill where he explains the SMPS walkthrough.
                4) After you have read the above documents, we will probably be asking for voltages on the SMPS controller IC. From there, we can hopefully track down the problem.
                5) If your board is like mine, the backside is not easy to get access to so you will have to find a way to ground the board to the chassis while measuring the backside.
                • a55bruce
                  • Aug 2010
                  • 26
                  Still reading through the posts, while trying to understand the circuit, I did make some measurements. With black on the trace from the diode bridge negative pin.
                  1) 9.7V
                  6) .36V
                  8) 152V
                  All the other pins read zero.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    1) 9.7V
                    6) .36V
                    8) 152V
                    Okay, PlainBill is the real expert and I'm still learning this part of the board. PlainBill might smack me on the side of the head, but if you want to try some of my suggestions, look below.
                    1) with power off, test the dual diodes "in circuit" that are mounted on the heatsink just right of the SMPS transformer. These should be the 2 diodes that provide secondary voltages.
                    2) if those test good, then with power ON, measure the voltage at pin 2 (middle) on both dual diodes
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      1) 9.7V
                      Okay, I'm wading through the SMPS datasheet and on page 13, it says Vstart should be a minimum of 10.3V and a max of 11.7V with typical being 11V.
                      You measure 9.7V DC. So we are quite a bit short.
                      Now if you look back to figure 4 on page 5, traceback from pin 1 to the components on the diagram and take voltage measurements.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        The service manual is at
                        http://www.nodevice.com/manual/newma.../get48311.html
                        but I don't have login. With schematics, it would help to know what leads to pin 1. There may be resistors in the path that are out of value?
                        • a55bruce
                          • Aug 2010
                          • 26
                          The diodes check OK, not shorted.
                          Not sure where to measure the voltages, center pin to center pin = 0V, from chassis ground to center pin, both=0V. Since the SMPS does not appear to running, those readings make sense to me.
                          I agree about the Vstart, I'll try to follow the circuit tomorrow..
                          • jetadm123
                            • 2169
                            A few suggestions:
                            1) Check the FET, Q102? mounted on the heatsink next to the 120uf cap for shorts.
                            2) Part of the startup circuit consists of D107, above F100 (check for short) and R137-140 (check resistance, I think they are 0.2ohm each)
                            3) Interesting tidbit. Another forum member has the same power supply you do, except his has sound and belongs to a Viewsonic VX2235! Goes to show you that these supplies are not subject to a single manufacturer. And I won't go into the different versions of these supplies. This person might be helpful in determining voltage measurements on your PWM controller, since it looks like he's got partial power:
                            https://www.badcaps.net/forum/showthread.php?t=10985
                            • a55bruce
                              • Aug 2010
                              • 26
                              ***Checks OK, no short between all pins, both directions
                              ***D107 OK, all 4 resistors are good.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                I found a free version of the service manual at
                                I downloaded and looked through but couldn't find a schematic of this SMPS chip. So it looks like you will have to "buzz" out pin 1 and trace it back to the SMPS transformer.
                                I believe there should be at least a diode or zener diode feeding into pin 1.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Can we get a clear focused 2000x2000 resolution shot of the area outlined in red? This is the SMPS area and the SMPS transformer winding that provides the power.
                                  • a55bruce
                                    • Aug 2010
                                    • 26
                                    1.
                                    Thanks for the link,
                                    I've been trying to trace the pin 1 circuit, and have not been able to figure out where the 9.7VDC is coming from. There does not appear to be any AC coming from the transformer to generate the 9.7VDC I'm seeing on pin 1.
                                    The circuit I have been able to trace out so far, resembles the one from FIG. 13 of the SMPS datasheet.
                                    • a55bruce
                                      • Aug 2010
                                      • 26
                                      Here's the picture....
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        If you refer to the datasheet, the TEA1532T has a slightly unusual circuit design. It uses a design that improves efficiency by 'turning off' the startup supply when the power supply is running normally.
                                        Pin 8 is tied to the low end of the transformer primary. That means when the power FET is turned off pin 8 should be at the same voltage as the main filter cap - typically 165 volts for 120VAC input. And it offers the option of monitoring the performance of the transformer and FET.
                                        During startup, the voltage on pin 1 (Vcc) is generated by a current source in the controller. Once the SMPS is working the current source is turned off and Vcc is supplied by a tertiary winding on the SMPS transformer.
                                        You reported Vcc is low. There are only a few reasons for that.
                                        1. The rectified mains voltage (at pin 8) is too low. It should be at least 125 volts
                                        2. The capacitor hooked to pin 1 is leaky
                                        3. The diode from the tertiary winding is leaky.
                                        4. The TEA1532 is defective.
                                        You have already shown that 1 is not the problem. Remove the cap, if the problem persists, the cap is good, thus eliminating 2. Similarly, temporarily removing the diode will test if 3 is the cause.
                                        Once you have eliminate the likely causes, the unlikely is the only thing remaining.
                                        PlainBill
                                        • bripoll
                                          Acer Veriton N4670GT Dead
                                          by bripoll
                                          Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                          The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                          It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                          I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                          I have programmed it, but it still won't start, it is dead
                                          Before programming...
                                          11-23-2023, 02:56 PM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
