Re: Crestron TPS-2000L with Sharp LQ5AW136R panel
Thanks. I would need to strip it down to get those photos. There's some info on the panel here, but no pictures of the boards inside.
I was hoping to get a steer based on others' experience on the likelihood of it being fixable. If it's highly likely to be the LCD matrix itself, rather than a discrete component on the board, then probably not much point in spending the time to take it apart.
If the reality is that the answer is "who knows" without seeing the board, then I'll take it apart and post some pictures.
We need to see some photos of the boards inside.Leave a comment:
I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other similar faults (though not on this panel) that e.g. the gamma correction IC could be the issue. See e.g. here
New panels are available, but they would need shipping from abroad and are quite expensive. The Crestron device itself is EOL. If it's likely to be an individual IC, I'd much rather just replace that.
Any help appreciated - thank you.Tags: None
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on... -
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....01-13-2024, 01:57 PM -
I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
...11 Photos - Loading...
