LCD 31MU97Z displays random lines randomly
  • Vspeed
    • May 2022
    • 53
    • Portugal
    I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
    I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ÂșC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V.
    The diode has 6U written on it. Do you think the diode is misbehaving or is the voltage somehow not stable?
  • lotas
    • Jan 2016
    • 4656
    • Russia
    Re: LCD 31MU97Z displays random lines randomly
    "6U" (SD12) is a 12 volt suppressor, you have a very high power supply to the panel, it should be 10 volts.
    • Vspeed
      • May 2022
      • 53
      • Portugal
      Could MP2315GJ be shorted or defective?
      I need to try and check it.
      • lotas
        • Jan 2016
        • 4656
        • Russia
        Yes, it could break through the input with the output (internal Mosfet), check the setting divider for the output voltage is R745, R746, R747 and the recommended resistor R726 at 62kOm.
        • Vspeed
          • May 2022
          • 53
          • Portugal
          All the resistors match the schematic. Also, IN and SW are not shorted, they read 0.567V in diode mode (black probe IN, red probe SW). The same between these and ground (red probe on ground)
          I took measurements for other MP2315GJ around and they read more or less the same values...
          • lotas
            • Jan 2016
            • 4656
            • Russia
            Replace with a new MP2315GJ, the input and output voltage must not be the same.
            • Vspeed
              • May 2022
              • 53
              • Portugal
              Found the issue. R746 was detached from the board on one of the legs. screen working fine again.
              Thank you.
              • lotas
                • Jan 2016
                • 4656
                • Russia
                Thank you.
                Yes, it is these resistors (R745, R746, R747) that set the output voltage to 10v, congratulations.
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Sharx112
                  ASUS VA27EHE randomly unstable
                  by Sharx112
                  Hello community. I've got an ASUS VA27EHE with a Panda LC270lf1l01 panel that started to behave strangely. A bit of intro:
                  If you power on the monitor without any inputs it turns on, displays the ASUS logo, shows no signal and goes into standby normally. When you plug it via HDMI sometimes and more recently, most of the times, it distorts the bios logo with horizontal lines, then when loading into windows 50-50 the windows emblem also is in horizontal lines. And after the system loads it almost always works properly, lol. On some rare occasions a part in the top of the monitor is being distorted...
                  03-26-2025, 03:42 AM
                • asr
                  Finding replacement diode iPad Pro 3rd gen A1701
                  by asr
                  Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                  Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                  07-09-2024, 06:24 PM
                • ca-gamer
                  MSI GTX 1070Ti problem with PCIE?
                  by ca-gamer
                  Hi All,
                  I have a problem with my 1070Ti.
                  9/10 times card fails to post in PCIE x16 socket. When it finally posts it shows random PCIE reading in GPU-Z. Rarely it shows x16, most of the times it will be either x4 or x1, sometimes x8. But still it will crash with BSOD in x16 slot sometimes even after 1 minute and sometimes it will happen after an hour.
                  Moving card to x4 PCIE slot improves it. It will post most of the time (I would say 8/10 times) and I can even play games for hours at full speed (I haven't spotted and slow downs in FPS vs x16). However randomly...
                  10-27-2024, 11:11 PM
                • jeyoung12
                  Samsung QN50Q60t lines on screen
                  by jeyoung12
                  Hi all
                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                  So....i don't know what end of the C ribbon to work with...
                  02-26-2024, 10:38 AM
