2 second to black on xerox XM3-22wB I need help please
--- begin sig file ---
--- end sig file --- -
Re: 2 second to black on xerox XM3-22wB I need help please
Here are instructions written from a different point of view.
Take a known good working LCD. Assume it has 4 CCFL connections. Number them 1, 2, 3, 4.
Take cover off known good working LCD and lay it face down on soft surface. You should be able to access the CCFL connectors.
Remove CCFL connector #1 from the good LCD monitor.
Plug in cable for potentially bad CCFL #1 into connector #1 for test.
Plug LCD into power bar and turn on power bar. Now power on LCD. See if 2 seconds to black occurs.
Turn off power bar, unplug LCD power cord. Wait 1 minute.
Repeat same instructions as above for each potentially bad CCFL.
If these instructions don't make sense, don't try it.
I have taken your advice and followed your instructions. I have uploaded a picture of the results of the 4 CCFL's. They all stay on for over 5 mins and so I ended the test.One of the ccfl was 15% pink at the end but still worked for the 5 min's as the other 85% was bright white as the other 3 (4 x 2mm x 475mm) So it may not be this that's causing my 2 second problem?
I have had the chance to re-photograph (in focus) the power board and also uploaded those images.The transistors/mosfets? have the no.K3615-6c on both printed on the part's,I have not re-worked these parts yet? They look good but my eye's are not great even using a mag lense light.
Thank you hoppalong ArtComment
Let's try this test to confirm.
You don't have to remove the Ilyana CCFL tubes from its housing, but try to CAREFULLY connect all 4 Xerox CCFL connectors to the Ilyana CCFL tubes. I realize the cables are short so you might have to "rig" up something to hold/prop the monitors together.
With this test, you will just get a white screen on the Ilyana monitor. If the Ilyana monitor stays on for 1 minute, we know it is the Xerox CCFL tubes at fault.
If we get 2 seconds to black, we know it is something on the Xerox inverter board.
If you put both these monitors onto a power bar, you can switch off the power bar if things go bad.
PS. That pinkish hue does mean that CCFL will die soon. So if this Xerox problem is solved, you may want to replace that one.--- begin sig file ---
--- end sig file ---Comment
Each LCD has its own type of controller IC that monitors voltage/current to protect the backlights. The threshold between backlight on/off will be different. So it is possible that this one pinkish CCFL is enough to cause the Xerox to shutdown, but not the ilyana due to the threshold tolerances.
Hello
I will get set up with that,and let you know how I fair
This is an image of the pink tube
Thank you
ArtComment
Oh yeah, don't let the monitors touch each other in case you short something out. One poster figured out that it was the CCFL tubes causing 2 seconds to black and then he accidentally shorted out the board.
I suggest putting something non conductive in between depending on how you got it rigged. See this fellow Canadian setup
https://www.badcaps.net/forum/showth...t=10861&page=2
He is also try to figure out 2 seconds to black. You can follow along even though you don't have the same monitor.
PS. The photos are a huge improvement in focus.--- begin sig file ---
Well they all worked using retiredcaps set-up advice! I am now going to try the next method.. ie plug them all in on the Illyama ..it only cost me a fiver and it's years old.. So in for a penny
Plus, It's the better half's and might stop her yakking Ha!
well here goes talk latter
Thank you
ArtComment
Yes this is the first day we have had a bit of sunshine, so I could get a decent image outside..ha! its August in glorious England,So what's new?
We have had all good weather up till now,So that's where the expression come from I suppose " It never rains until it pours"
A question? What would possibly happen If I reassemble all the bits (there everywhere at the moment) Just with 2 tubes or 3 tubes Just a thought...
A voltage overload maybe or what?
ArtComment
I have the ccfl's already detatched from the xerox as separate units? So no problem by putting the two screens together
I hope that makes sense
I will just unplug the Illyama leads and plug in the xerox ccfl's with a quick safety switch on/off and see what happens?
ArtComment
Depending on the controller IC, it will probably shutdown due to an underload or overload condition. I think there was a thread to try and "trick" the controller IC into thinking there was a "phantom" CCFL tube, but I don't remember the outcome.--- begin sig file ---
I understand what I have to do regarding the next test
Hook up the ccfl's from the Ilyama to the xerox power board (so I am trying to put back together the xerox,,) I will have to rig extensions cables not a problem
I just have a bit off a problem at the moment though?. when I took the screen out of the xerox I thought I had images recorded to know how it all goes back together ...did I heck! They are missing. I have the glass, the lcd plastic with a rough surface (one side is shiny and the other has the feel of nodules I suppose they are the electrodes which goes where I don't know and a various amount of plastic sheets all supposed to be in the sandwich,, Huh! I cant find out anything on the net yet. on which order it goes in...worst case take the ilyama apart and see the order of things...I hope you are having a nice week end
ArtComment
Hello all watching this thread, with thanks to retiredcaps
I am drawing a line under it as I have broke two lamps trying to put back the screen and also my llyama will not show images now? but the lights are on, So I have a nice winter job to solve..I am going to order more ccfl's for the xerox and see how it goes
Thanks for all your help
ArtComment
If that doesn't work, post back and we will try to get the Ilyama working again.--- begin sig file ---
Bad luck,but I said its not easy,Still I'm sure from your posts that you have quite enjoyed this little trip into the world of PC Monitors,and wish you well with this one >>>>AND>>>>>any others you may have a go at.Comment
Art
Al.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
I haven't replaced any lamps myself, but I thought about doing it for a laptop for one of my friends. After I saw how small they were, I decided not to take a chance. The LCDs are larger and more forgiving, but still very fragile.
If you are getting an all white screen, I suggest rechecking the cable connections. It is easy to miss one or not have it fully plugged in.
I thought as much, but I lost the plot, when I broke the xerox lamps so I will get back to it when my minds clear...Thanks retiredcaps
I don't know what price you could replace your monitor.And how much you are willing to spend on it but there is a company here in the usa that sells complete ccfl assemblies. It's name is ccflwarehouse.I have purchased single bulbs from them,but never complete assemblies.There tech support is very good and I have very good luck with them.
Al.
I have purchased a LG 22" to see me though for now @£89.00
thanks again all I shall return
ArtComment
If that doesn't work, post back and we will try to get the Ilyama working again.[/QUOTE]
Hello again
Just an update I have not had the chance to do anymore to the xerox and have found the problem on the Ilyama, one of the connection tapes (They are a laminated celloloid type material with wires embedded) that I would normally remove by pulling the white tag,has been servered, Oh dear!!! what a plonker I am, I hear you say...I cant see any way of joining this back up again? unless there is a magical remedy, I am flumuxed...
I hope your all well
ArtComment
https://www.badcaps.net/forum/showth...oken+connector
post #38 and 39
https://www.badcaps.net/forum/showth...ht=tape&page=2--- begin sig file ---
by ManiackkHello,
Device: PocketBook InkPad 3
Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
I would appreciate help identifying this component.
Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...2 Photos -
This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...09-12-2024, 02:00 PM
This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-12-2024, 01:58 PM
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
- Loading...
