EVO car radio -blank screen
  • Cornboats
    Dave
    • Oct 2010
    • 232
    • United Kingdom
    I've had this in my Isuzu since I bought the truck in 2003. Stopped working and now on my bench for fault finding. Fuse at the back of the set is ok, testing using a 12v DC supply. 1st port of call was a disable button that you can remove which is supposed to deter theft. Looked at this first. When you insert it shorts 2 pins to make a circuit. Shorted pins out with white wire just to confirm.
    2nd was the volume control which is pushed to activate a momentary switch to turn on /off. Test ok with ohmeter but ran white leads from pins just to check. Voltmeter shows 4.8v on to one of the pins and on both pins when button pushed.
    Visual check on main circuit board and diode tested transisitors / fets I can see.
    Now I'm stuck. Where do I go from here. Any help and advice would be greatly appreciated.
    • 31040
    Re: EVO car radio -blank screen
    clarify,
    "blank screen"
    does the front light up? does it output sound?
    • Cornboats
      Dave
      • Oct 2010
      • 232
      • United Kingdom
      Nothing happening. No sound, no light. If you take out the removable button the led flashes, which its supposed to.
        • 31040
        check the soldering on the power amp, some of those include a fet-switch to control power
        and check any crystals or resonators are running
        • Cornboats
          Dave
          • Oct 2010
          • 232
          • United Kingdom
          Just an update. I found a transistor BD438 with a shorted leg. I've replaced but still have a dead set. There are 3 voltage regulators on the board 1 of which is adjacent to the transistor BD438 I've just replaced. I'll test these with the voltage on next. There is a smd transitor 3F P23 connected to the BD438 which is giving correct readings but then so was the BD438 until I pulled it. I'm reluctant to pull the smd transistor for fear that being so small I'll never get it back.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • dicky96
            HP Elitebook Screen blank - backlights but no image
            by dicky96
            Hi guys
            I'm trying to fix this laptop screen
            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
            OK so I have the original screen which works but has lines across the bottom quarter of the screen
            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
            04-28-2021, 07:30 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • Kalman27
            Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
            by Kalman27
            We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
            We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
            I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
            Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
            06-17-2025, 05:52 AM
