Harman Kardon AVR 171S - standby led lights up, does not turn on
  • madsox
    • Jun 2020
    • 13
    • Csongrád
    Greetings!
    Thank you in advance for your understanding, I am writing to you through a translator.
    A Harman Kardon AVR171S amplifier was given.
    The history of the machine is as follows:
    It was faulty when I bought it, I want to fix it.
    I replaced the HDMI switch and one of the DAC ICs in it.
    After that it worked without a problem.
    I watched a movie using the amplifier, and at the end the amplifier got really hot.
    The cooling was faulty, I will fix this later.
    I switched it to standby mode, waited for it to cool down, then took it apart to fix the cooling.
    After that, the machine did not turn on.
    The standby LED lights up orange.
    It does not respond to the power button or remote control.
    Pressing the surround mode button for 5 seconds does not reset.
    The power supply only supplies standby 5V.
    The STM microcontroller starts, it is not in reset due to low supply voltage (by IC1503), the correct 3,3V is present.
    By visual inspection, there are no faulty, burnt parts or humped capacitors.
    On another forum, I was advised to check the voltage value of the POWER_DOWN pin, because the PC95 optocoupler may be faulty.
    I measured at the input of the optocoupler (PC95):
    AC 0,75-0,82V; DC 0,38-0,45V
    On pin 15 (POWER_DOWN) of connector BN65:
    AC 2,47V; DC 0,56V
    I think here that the DC 0,56V is low for the processor, that's why it won't turn on.
    Voltages measured on some legs of the controller:
    1. PROTECT: DC 3,32V
    2. POWER_FAIL: DC 3,32V
    3. POWER_DOWN: DC 1,89V
    Do you think the optocoupler is faulty and that is why the device does not turn on?
    Is it because the amplifier does not turn on because it does not detect the correct input mains voltage?
    Does anyone have an idea where I should look for the error?
    (Unfortunately, I don't have an oscilloscope, but if you ask for a measurement, I will do it with my multimeter and report back with the results.)
    I trust your experience,
    I really want to use the amplifier.
    I have attached the service manual.
    Thank you, Thomas
    • 31267
    Re: Harman Kardon AVR 171S - standby led lights up, does not turn on
    how did you fix the cooling, did you replace a 3wire fan?
    • madsox
      • Jun 2020
      • 13
      • Csongrád
      The temperature sensor was mounted on the power supply (on the 12V voltage stabilizer) instead of the heat sink of the amplifier transistors.
      Someone tried to fix the amplifier before me, I wasn't the first.
      If that doesn't help, I'll install a fan controller (https://www.aliexpress.com/item/1005004752252602.html) for proper cooling.
      They have worked great for my computers, it will be good here too if the built-in controller is faulty...
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        does it have a self test mode ? proceed with caution if it has
        • madsox
          • Jun 2020
          • 13
          • Csongrád
          I did not find any reference in the service manual or user manual to any self-test function.
          Thank you.
            • 31267
            does it have a 3 wire fan?
            • madsox
              • Jun 2020
              • 13
              • Csongrád
              No, the amplifier has 2 wired fans.
              On the ali' control panel, the fan pwm leg is connected with the input connector pwm pin, it is not used to speed control.
              Or what are you thinking?
              • barg8
                • Oct 2023
                • 4
                • Polska
                Hello everyone
                I have the same problem with my AVR 151s
                You successfully solved the problem ?
                • barg8
                  • Oct 2023
                  • 4
                  • Polska
                  • madsox
                    • Jun 2020
                    • 13
                    • Csongrád
                    Hello.
                    Unfortunately, I didn't make it any further, it's been standing for a year.
                    I found a good solution for a Focusrite sound card, but the topic seems to have stopped.
                    I tried to ask in other places, without success; the questions stopped just like that, no matter how much I brought them up again and again.
                    If you manage to get any information, I would be very grateful if you could pass it on to me.
                    Although, now I'm at home sick, I also got an oscilloscope.
                    I'll dig into a few and see if I can find anything.
                    • madsox
                      • Jun 2020
                      • 13
                      • Csongrád
                      Well.
                      I measured the digital PCB.
                      And it's the worst.
                      The microcontroller have shorted.
                      How to replace that, I really don't have idea.
                      Okay, the IC is available, but the program. . .
                      • barg8
                        • Oct 2023
                        • 4
                        • Polska
                        How to check this short circuit and in what system it occurs
                        • madsox
                          • Jun 2020
                          • 13
                          • Csongrád
                          Where can you short circuit? Anywhere.
                          Any capacitor, any resistor, IC or transistor can go into short circuit.
                          I found it by unsoldering the components one by one, measuring, unsoldering, measuring... in the end there was nothing between the +3.3VC and the GND line, only the controller.
                          Of course, it is worth searching for each part and island.
                          There is the injection method, but I haven't tried it yet.
                          With this method, the short-circuited component can be heated within the circuit,
                          and it can be determined from the rate of alcohol evaporation or found with a thermal camera.
                          • barg8
                            • Oct 2023
                            • 4
                            • Polska
                            I check all my pcb and i dont have short circuit 3,3V to GND :płacz:
                            • madsox
                              • Jun 2020
                              • 13
                              • Csongrád
                              You have to measure, even with an oscilloscope, and look for oddities and anomalies.
                              Unfortunately, I can't say more, but maybe another forum member can give me an idea.
                              I change the e.capacitors first, they are the first ones that generally break down.
                              If it doesn't help, I'm looking for a heating part.
                              If there is, and it is suspected to be faulty, I will replace it without a thinking.
                              If it doesn't help, the scope and thinking with my hands on the wiring diagram will come.
                              I hope you have more success than I have so far.
                              I contacted Harman Kardon, they referred me to a service center, who said it was beyond repair.
                              I don't care about that.
                              Don't let it become garbage just because of its single microcontroller program unavailable...
                              • TunedPort
                                • Mar 2024
                                • Usa
                                I also have a Harman Kardon AVR2650 STANDBY LIGHT TURNS ON , but occasionally will not turn on .
                                • Bjurstrom
                                  • Aug 2023
                                  • Norway
                                  Hi Everybody .
                                  i got a AVR 171S for free yesterday , "same" symptom as you describe . Standby light is on , when i power it on , white light for aprox 10 sec, no text in display and then back to orange.
                                  Put it straight on my bench and popped the hood , a strange hissing sound from the SMPS , started meassuring the voltage lines and soon found out 12 V + was missing .
                                  Regulator IC97 (7812A ) ok , but the smoothing capacitor C 933 was all dried out . Replaced cap , unit is up and trunning :-)
                                  Hope this helps someone :-)
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • unilogic
                                    Harman Kardon AVR-355 going into standby
                                    by unilogic
                                    My AVR-355 switches itself to standby mode after a few minutes, when it becomes warm. If I turn it back on, it doesn't shut off anymore and can run for hours. If I let it cool down for a few hours and then turn it on again, it shuts off again after a few minutes. But no more problems if I turn it back on immediately. This always happens, even if the device is not connected to anything. I don't see a "protect" message or anything special. The device simply goes to standby (amber power button)
                                    I did a complete reset of the CPU, but the problem persists...
                                    I have attached...
                                    04-11-2021, 03:40 AM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
                                  • Crystaleyes
                                    Samsung BN44-00259A standby question
                                    by Crystaleyes
                                    Hi all.
                                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                    08-11-2023, 05:15 AM
                                  • PowellSkier
                                    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                    by PowellSkier
                                    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                    06-17-2024, 11:43 AM
