mhc-nh1 problem with the audio
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi i have the above stereo sony
    operates normal the front speaker
    the rear and center no
    Ιs there any chance that it is optional?
    to have been deactivated, I mean
    or STK is the most likely cause
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • falcontech
    MOTU TRAVELER MK3 AUDIO PROBLEM
    by falcontech
    Good Afternoon
    I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
    01-24-2025, 08:47 AM
  • Gibon378
    Problem with stopping audio and video for no reason
    by Gibon378
    PC Specs:
    • CPU: Ryzen 5 1600
    • GPU: GTX 1080 Palit JetStream
    • MOBO: ASRock ab350 PRO4
    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
    • PSU: XFX 650W (don't remember what model)
    • OS SSD: ADATA SP920
    • OS: Windows 10 21H2
    Problem description:
    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
    11-19-2022, 09:41 AM
  • tk5ep
    Stanmore JN3018 audio problem help request
    by tk5ep
    I've been given a non working Stanmore JN3018 loudspeaker.
    The power supply part works normally, I have all voltages on all chips. But no sound is coming out.
    I tried to track the audio signal from the inputs to the loudspeaker.
    Unfortunately, it's not easy, as most signals are PWM. But the analog part is working, and I can track the PWM at the inputs of the TAS5508c.
    At the TAS5508c output, I only have pulses which I can find on the input of the final amplifier TAS5342a.
    Can somebody help me to resolve this problem ?
    02-16-2025, 10:46 AM
  • PapaFi
    Teac AG-D9260 AV Receiver Audio Problem
    by PapaFi
    After turning ON the unit, as the 2nd relay clicks. No audio response even radio or from dvd player. During vol adj from remote/manual adj as the vol increased there's a loud "tic" sound from the speaker. Even up to max vol still no audio. As you played the adj +/- from remote/manual along with the loud "tic" sound. All of a sudden the audio turned ON but uncontrolled vol even +/- adj. looks the audio is stuck on its level of vol. Even max/min audio level is the same (but the "tic" sound still there as the adj from min to max and vice versa and of course as you reached...
    08-26-2020, 04:04 AM
