Pioneer turntable tone arm adjustment
  • Dobsuk
    • May 2020
    • 127
    • England
    Hi all. I have Pioneer PL-Z460 turntable but have some issue with the tone arm.
    When the record finishes or stop it manually the arm does not go back all the way to the rest. It stops just short and then decends down onto the base. Is there an adjustment to make the arm go back a futher 0.5 cm?
    There is only one screw at the base of the arm but it is for height adjustment:
    Any advise please?
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: Pioneer turntable tone arm adjustment
    sometimes there is a screw on the rear inner side of the arm .
    • redwire
      • 3912
      It's usually due to a bent rod in the mech, or the cam has rotated. If someone was rough with the tonearm, or a kid trashed it. It must be more than a few mm out.
      There would be no adjustments outside. Have to take it apart and get to the underbelly.
      • R_J
        • 9634
        Does the tonearm land properly at the start of a record? or is that off as well? There is another adjustment besides the height adjustment
        • Dobsuk
          • May 2020
          • 127
          • England
          It does not start automatically. I need to position the arm.manually to start. It just stop automatically.
          There is no other screw beside the height adjistment:
          Just one spring can see on the back of the arm:
          • Dobsuk
            • May 2020
            • 127
            • England
            Yeah maybe will have to take it apart
            • R_J
              • 9634
              move the tonearm to the position where it would normally auto return (near center of record) and see if there is a Philips head screw in the location I marked.
              The shaft from the tonearm goes into the lower plate and should be held with a screw, it could be that someone forced the tonearm and it turned in the lower plate, or the plastic that holds the screw may be cracked
              • Dobsuk
                • May 2020
                • 127
                • England
                I saw that earlier but it is not like a screw and it does not stay still.
                It is moving the arm backward and not sure if i can adjust it somehow.
                • R_J
                  • 9634
                  That looks like an allen key for the adjustment. and it likely did not go out of adjustment. I suspect the tone arm got pushed toward the center spindle and the small screw (under the tone arm mechanism) holding the tone arm slipped.
                  When you move the tone arm toward the resting position, and it stops, can you push it a bit further and see if it lands closer to the rest.
                  The tone arm shaft that goes down into item 105 (or 106) and would just spin if it was not secured by the screw (green arrow). If the shaft was turned too far, it would just slip as the screw does not provide that much force to prevent it from turning.
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    Yes, i can move it all the way i want and to set it down on the rest.
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      I think i managed to adjust the arm with this torx. It is better now. Thank you all
                      • Mark R
                        Marantz Model 150 Tuner "NULL" Adjustment..
                        by Mark R
                        I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                        Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                        12-30-2024, 03:18 PM
                      • redwire
                        Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                        by redwire
                        My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                        Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                        Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                        The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                        The tone caps are green film caps I left alone. Newer...
                        07-30-2023, 08:21 PM
                      • EduCabral
                        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                        by EduCabral
                        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                        🔧 Details:
                        • Model: YT-M06
                        • Interface: Pioneer 1
                        • MCU: Fujitsu MB89F202
                        • Goal: Find a valid .bin firmware file or memory dump from a working unit
                        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                        07-15-2025, 12:26 AM
                      • pixelcap
                        Pioneer Kuro Pro 111FD 8 red blink error
                        by pixelcap
                        Pioneer Kuro Pro 111FD 8 blink red LED.
                        I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                        So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                        based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                        10-06-2024, 11:26 PM
                      • RatherLoopy
                        Pioneer VSX-44 receiver HDMI dropouts
                        by RatherLoopy
                        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                        05-26-2023, 03:54 PM
