Marshall Stanmore II voice with the google assistant built-in
  • dysk1
    • Aug 2019
    • 11
    • Tychy
    I'm Marek and I'm from Poland.
    I bought on our auction site 5 pieces of damaged Marchalla speakers. I'm an electronics engineer and thought I would fix them myself. I was very disappointed with the construction inside.
    As power amplifiers there are 2x TAS5711. Everything is controlled by a ready-made module from Frontier Silicon MINUET FS5332. In the attachment I send pictures of the PCB. All 5 pcs have the same fault. The power supplies have 24V at the output. After connecting the power supply from the lab power supply, you can see how the current floats from 0.04 - 0.26A. No buttons work and no signs of life on the front panel. I suspect a software fault.
    Please help me in repairing this speaker.
    Someone did not disable access to such a speaker and it can be accessed through an external IP. http://59.11.201.30/
  • CapLeaker
    Leaking Member
    • 8056
    Re: Marshall Stanmore II voice with the google assistant built-in
    Does it have something like an UART? Maybe hook your computer up to it and see what’s going on. You could also get a dump from a working speaker and copy the working flash to your non working ones.
    Is there a reset procedure for it?
    • dysk1
      • Aug 2019
      • 11
      • Tychy
      Does it have something like an UART? Maybe hook your computer up to it and see what's going on. You could also get a dump from a working speaker and copy the working flash to your non working ones.
      The reset procedure is like this: "Press and hold both the Source button and the play/pause button for 7 seconds," but it doesn't do anything. I can't see the UART, but there is a USB service port. I opened this FS5332 and made an overview shot. All voltages on the board are correct.
      Located layouts:
      88DE3006-BTK2 Marvell
      NT5CC256M16EP-DI Nanya
      88W8887-NAA2 Marvell
      TC58NVG2S0HTAI0 TOSHIBA
      Unfortunately, I have nowhere to get a working speaker. The seller has 50 more speakers broken in the same way. Very strange case.
      • CapLeaker
        Leaking Member
        • 8056
        So what happens if you remote into the speaker using that IP? Does anything happen?
        Right there were that module plugs into the other board, there are three pads labeled GND, TX, RX. Probe it if it could be TTL. See what it does.
        • budwich
          • Jul 2015
          • 3097
          Located layouts:
          You indicated the reset procedure... BUT how are you attempting to turn the unit on. The reset only clears the unit back to factory settings... it doesn't turn the unit on.
          • dysk1
            • Aug 2019
            • 11
            • Tychy
            3 out of 5 speakers were repaired.
            The first repaired after several reset attempts.
            In the second one, I found a capacitor short-circuited.
            In the third, I found a damaged resistor.
            I have not fixed the fourth one yet, based on the current consumption and the thermal imaging camera, I can see that the linux itself is loading but it probably does not execute the program.
            The fifth play is still ahead of me.
            • CapLeaker
              Leaking Member
              • 8056
              Sounds like you are making progress!
              • malycinek
                • Mar 2023
                • 8
                • Poland
                Hey. I got problem with Acton II Voice, problem is it is not starting. Top panel is not working, it looks like all voltages are present. Strange thing is that RT8059 which is powering top panel diodes (3.3V) is starting soo long. (like 20-30 secs after powering speaker on). Have you maybe found similiar problem? Maybe know reason basing on your big experience? Looking forward to hearing from you!
                • jules91
                  • Jan 2023
                  • 4
                  • France
                  Hi
                  I have also a Marshall Acton II voice with similar issues.
                  When I power on, the 4 leds on the front panel blink 4 times but nothing append after.
                  Do you have find a good solution with your Marshall speaker about it?
                  • malycinek
                    • Mar 2023
                    • 8
                    • Poland
                    Originally posted by jules91
                    Hi
                    No solution. In my case leds are not working.
                    • jules91
                      • Jan 2023
                      • 4
                      • France
                      I think the problem may be a capacitor. Try to see if yours looks normal or not and if possible test them.
                      • malycinek
                        • Mar 2023
                        • 8
                        • Poland
                        I checked capacitors, no shortcircuits, all voltages present. Still not working.
                        • yajdeeks
                          • Jan 2019
                          • 6
                          • Poland
                          Hello, i need dump from nand memory
                          • malycinek
                            • Mar 2023
                            • 8
                            • Poland
                            I have two NAND dumps from different damaged Marshall Acton II speakers. Maybe someone will find them useful. I'm not sure if they are working dumps, but if someone can check and make use of them, please let me know.
                            • Rocinante
                              • Jun 2025
                              • 3
                              • Romania
                              Hi there,
                              I have the same issue as you. I have a Stanmore II with voice assistant, and I can't find any problems with the boards. All voltages are present, but it doesn't power up. The small board gets a little warm, as dysk1 mentioned and as shown in the thermal picture.
                              Has anyone tried to access the console via the GND, TX, and RX pins near the large black connector? Maybe I can see if it boots correctly.
                              Is it possible to reflash the NAND through these pins? Or should I remove the Toshiba chip and program it with a TL866 or something similar?
                              Also, how did you extract the dumps?
                              Thanks!​
                              • malycinek
                                • Mar 2023
                                • 8
                                • Poland
                                Hey, with console you can check if system is booting. You need serial to usb adapter to open console. You can program toshiba nand after desoldering and putting into adapter and programmer. It may work with tl866. Im pretty sure your firmware is also corrupted.
                                • Rocinante
                                  • Jun 2025
                                  • 3
                                  • Romania
                                  I think you are right. This is what i get on console, in loop:
                                  [QUOTE][/QUOTEGalois
                                  ->tw:irq enable: 0x2000
                                  ->tw:fiq disable: 0x2000
                                  ->tw:kernel start ...
                                  ->tw:free memory(0xb1090) at 0x204af70
                                  ->tw:TEE TW version 1.12.21, build time 15-04-08 21:01
                                  ->tw:proc log buf: 11080000, ctl: 11180000
                                  ->tw:init module 2029420
                                  ->tw:init module 2037ca8
                                  ->tw:init module 203b4cc
                                  ->tw:init module 20389f0
                                  ->tw:init module 203c33c​]
                                  Did you know how to solve it? I am able to desolder the toshiba chip and i can buy a programmer, but im not sure how to get the firmware. I saw 2 in a previous post but i dont want to invest in a programmer if im not sure i have a working nand dump. Thanks!
                                  • malycinek
                                    • Mar 2023
                                    • 8
                                    • Poland
                                    Hey, it is exacly same console output as mine. So your firmware is corrupted. Same as mine. We need to find firmware dump to fix this.
                                    • Rocinante
                                      • Jun 2025
                                      • 3
                                      • Romania
                                      You didnt try the dumps from post 14?
                                      • malycinek
                                        • Mar 2023
                                        • 8
                                        • Poland
                                        These are mine dumps. They are corrupted sadly, but maybe they will help someone to repair dump or something. I think experienced person can find broken block and replace it, thats why i attached it.
                                        • Kezi Gamer
                                          Marshall stanmore multi room
                                          by Kezi Gamer
                                          Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                                          03-24-2025, 08:37 AM
                                        • jingleslacks
                                          Marshall Stanmore II - chip flash
                                          by jingleslacks
                                          Hey Friends!
                                          I have both a live and demo unit. Demo unit firmware disables Bluetooth, power toggle, and other settings. Resets via button combos will not work on these. Reaching out to Marshall is not an option either.
                                          I copied my live CMOS chip and flashed it to the demo unit, but that didn't fix it (MX25U3235F) This has worked for other devices in the past. I'm not a chip expert, but I'm assuming the firmware is stored in another chip.
                                          If anyone has any experience or ideas, let's hear them!
                                          Stanmore II
                                          Stanmore 2​...
                                          03-23-2024, 05:09 PM
                                        • thuygsm
                                          Marshall Stanmore 2 (flash chip)
                                          by thuygsm
                                          hello
                                          in my case, the Bluetooth - AUX - RCA signal light goes off after 5 seconds and repeats, (sound is there then 5 seconds then gone and repeats)
                                          i forgot them and reconnected, but they do not play on the speaker, although i can still adjust the 3 modes Bluetooth - AUX - RCA (on the phone)
                                          after i loaded a new rom, i lost bluetooth connection and could not power off, no boot sound. i loaded the previously saved rom again, but the situation still cannot find bluetooth and boot sound
                                          hope everyone can help​
                                          04-08-2025, 10:27 PM
                                          HP Elite Slice G2 + Google Home Hub Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Google Home Hub can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Google Home Hub boardview and Elite Slice G2 + Google Home Hub schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:20 PM
                                          Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook Spin 713 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...
                                          09-07-2024, 03:10 AM
