Pioneer Xdj-rx
  • falcontech
    • Oct 2013
    • 470
    • italy
    Pioneer Xdj-rx
    Hello
    Today I am struggling with a controller for dj xdj-rx, I have a low volume on the main output of the master compared to the booth, both should have + 6db output but the difference is heard enough, I saw that on the board where the various outputs the master is driven by 2 njm4850d, could they be the problem? thanks to those who can help me, I do not have an oscilloscope, I cannot attach the service manual because it is too heavy if it were to be needed I have one
  • falcontech
    • Oct 2013
    • 470
    • italy
    Re: Pioneer Xdj-rx
    Originally posted by falcontech
    Hello
    Sorry 4580d
    • stormanimal83
      Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
      by stormanimal83
      i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
      08-04-2024, 01:47 AM
    • Bushcat
      Pioneer PL-X9 motor speed control wobble
      by Bushcat
      I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
      Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
      BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
      05-24-2023, 03:36 AM
    • pixelcap
      Pioneer Kuro Pro 111FD 8 red blink error
      by pixelcap
      Pioneer Kuro Pro 111FD 8 blink red LED.
      I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
      So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
      based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
      10-06-2024, 11:26 PM
    • RatherLoopy
      Pioneer VSX-44 receiver HDMI dropouts
      by RatherLoopy
      I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
      I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
      And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
      05-26-2023, 03:54 PM
    • The WABBIT
      Dell Inspiron 5559 need BIOS Master PW
      by The WABBIT
      I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
      After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
      Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
      07-12-2021, 04:20 PM
