DIY amp for speakers
  • evilkitty
    • Nov 2017
    • 299
    I have these parts:
    Looking at this amp board:
    https://www.ebay.com/itm/384899115622
    I want to take the front header audio from the sound card and run that to the amp which will be mounted to a old PCI 54k modem's bracket (speaker wire would pass though the hole for the RJ11 socket) and i would power this amp board using my system PSU, now this board says 12v is in the operating voltage range, but should i be using a boost converter? if so what is a cheap one i can get for this? i'm not sure how many amps this amp pulls
    i assume this amp board is reasonable for these speakers
    Maybe this converter would be fine? https://www.ebay.com/itm/384733453111
    • Jul 2011
    • 6037
    Re: DIY amp for speakers
    I would highly suggest that you use very good quality wiring that is shielded for best results
    Also get a good quality power amplifier that only requires 12 volt maximum for best results the one you chose would be ok but I do not know if I would use a boost converter you might have interference from the converter weather or not could use filtering capacitors if this is an issue
    One thought if could find a Bluetooth card for a computer interface might be better choice if you want to use higher voltage on the amplifier module
    With the amplifier that you choose make sure that it can handle 6 ohm speakers
    And you should have a good sounding system
    Back in the day when sound cards came out there were good sounding systems I have one that I use on my computer but I would not be able find another one with this quality
    You might be able to use what you have in mind with out issues but just keep in mind that using a boost converter might be an issue
    • evilkitty
      • Nov 2017
      • 299
      That amp says it can do 120W speakers, my speakers says 120Watt max and 35W nominal, so i assume it can handle them based on that
      Managed to find more info on the amp, if you run at 12v you can do 50W speakers
      as far as noise from a boost converter can i not use one of these? https://www.mouser.com/new/coilcraft...wer-inductors/
      i do not plan to run these speakers at max volume (it is a small room, seems like a bad idea to do) so i guess i could just run at 12v and effectively just cap the volume?
      • evilkitty
        • Nov 2017
        • 299
        I found a different board that uses 2 of the same chip so it can handle more current: https://www.ebay.com/itm/302749492150
        https://www.ti.com/product/TPA3116D2
        if i use a boost converter to power it at over 12v this is not gonna really pull ~17 amps from my power supply will it, speaker watts are not the same as actual power draw there is it? i find it hard to believe that could be how it really works, but it would explain why amplifiers cost so much and they would need to be built with 1200W power supplies and would need on dedicated breakers
        • lti
          • May 2011
          • 2547
          Figures 13 and 14 in that datasheet show the maximum output power over the supply voltage range. I would guess that you'll get about 10W per channel into 6 ohms.
          Power consumption will vary with the audio level.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Yesterday, 05:17 PM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • gizmo1990
            What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
            by gizmo1990
            I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
            The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
            10-21-2024, 08:02 AM
