Yamaha RX-A1020 protect
  • hanasaku
    • Mar 2022
    • 9
    • sweden
    HI, i wonder i someone can guide me with my yamaha receiver, i test almost everything that i found on the net, im run out of option, i have in all the channel -7v and just the right front -5.2v, i check and i have randomly 6 and 8 v from the signal AMP_OLV, all the power supply signal are ok, sometines i have goog voltages on the +B and -B but now a have 70v and -55v.
    Thanks for the help
  • hanasaku
    • Mar 2022
    • 9
    • sweden
    Re: Yamaha RX-A1020 protect
    anyone can guide me?
    can be a floating ground i suspect, or a bad capacitor.
    thanks in advance.
    • hanasaku
      • Mar 2022
      • 9
      • sweden
      i found something on the right channel, the resistor R1111 3 point 22ohm x2 just one side was ok, and the diode D1028 was open/Bad.
      i will check changing this .
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        check the output transistors .
        am guessing the resistors are 2x 0.22 ohms
        • hanasaku
          • Mar 2022
          • 9
          • sweden
          yes. one of the 0.22 ohms resistor fail, i already change and the diode but burn the transistors on the right channel .
          • hanasaku
            • Mar 2022
            • 9
            • sweden
            I suspect the problem is in the -LB signal because R1287 and Q1098 are extremely hot but they work, also the signal shorting the double resistor is the positive transistor Q1048P which is connected to the -LB_R
            • hanasaku
              • Mar 2022
              • 9
              • sweden
              This 2 components are hot even if i isolate the amp side , Its that normal?
              • sanalelevenstar
                Yamaha RX-V485 Wn9711 Update
                by sanalelevenstar
                Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                12-04-2024, 04:32 AM
              • sanalelevenstar
                Yamaha RX-V485 receiver. After encountering a "version error"
                by sanalelevenstar
                I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                I managed to find the service...
                09-10-2025, 01:54 AM
              • jjne
                Yamaha RX V675 sound issues
                by jjne
                I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                At first I thought it was either a speaker relay or the DSP, but I don't think...
                06-24-2025, 07:01 AM
              • AlexVG
                YAMAHA CLP-550 without of sound
                by AlexVG
                Hi.
                I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                I have replaced all green marked elements, but it gave me nothing.
                The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                But it is custom YAMAHA's chip, and I can't find any information about it.
                Maybe somebody came across with the same issue?
                Any information will be very useful. I will be very appreciated.
                Thank you....
                06-08-2025, 09:29 AM
              • hemant_2222
                Yamaha RX-A1020 full dead
                by hemant_2222
                Hello Everyone,
                Greetings!
                It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
                09-14-2024, 11:25 AM
