Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    I have a Panasonic SAPM-31 mini hifi and the tape deck motor keeps spinning all the time
    If I just connect the ribbon cable to PCB That is connected to the motor, it spins continuously
    If I change the input it still spins
    I have put it all back together with all the belts in place and still
    I can play, forward and rewind but the motor never stops when I press stop
    This never used to happen so I am not sure if a transistor has failed or a diode
    I will really appreciate the help from this forum
    Thanks all
    Here is the service manual
    https://www.manualslib.com/manual/14...-Sa-Pm31p.html
  • R_J
    • 9556
    Re: Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
    I suspect this is normal as the motor operates the mechanism when a button, ie Play is pressed. The motor runs in tape standby and when you hit IE(play) the plunger solenoid activates the mechanism, as there are no mechanical buttons to engage the mechanism.
    If you select CD, does the motor tape motor stop?
    • lcdcaps1
      • Oct 2011
      • 322
      Originally posted by R_J
      I suspect this is normal as the motor operates the mechanism when a button, ie Play is pressed. If you select CD does the motor tape motor stop?
      Hi
      No it does not stop when selecting other modes
      I have been told it is not normal and this never used to happen to me before
      • R_J
        • 9556
        Originally posted by lcdcaps1
        Hi
        Looking at the logic of Q1314 (page 61) the base should change from 1.9v to 0 volts in standby, this will change Q1314 collector from 10.1 to -0.1 volts
        But looking at the voltage on Q1316, it's collector only changes from 0.1 to 0, This suggests the motor - is always low (motor ON)
        • lcdcaps1
          • Oct 2011
          • 322
          The motor did not used to run continuously
          Not sure what's happened for it to start doing it now
          It doesn't stop when selecting other inputs Ask when stop js pressed it doesn't stop
          Something is up and not sure what
          I've read it could be a transistor
          • lcdcaps1
            • Oct 2011
            • 322
            After checking your voltages
            Pin 2 on c309 goes from 2v to 9v on startup and then steady 9v
            Q310 collector voltages on startup goes from 2v to 9v
            Q310 base has no voltage, when running
            When I keep my meter red probe on q310 base I get 1v for a blip and goes to mv
            • R_J
              • 9556
              Q310 base is controlled by the logic from the microprocessor. 0 volts on Q310 base means that Q310 is not turned on, so the collector will be high. If you want, short pin2 of cn309 to ground and see if the motor turns off.
              These type of tape decks need the motor to be running so that when you press a function, the plunger engages the mechanism WHILE the MOTOR is running. If the motor is not running when you press play nothing will happen.
              Tape decks that have levers that you push to engage the mechanism keep the motor off until the mechanism is engaged. This is not how this mechanism works.
              The tape motor may turn off after 10min of non use. see if you don't play a tape and let it sit, maybe the microprocessor program will turn it off.
              • lcdcaps1
                • Oct 2011
                • 322
                Thanks for the reply
                After looking at the schematic. I can see they state q309 as a plunger switch that works fine
                Also stated is q310 is a switch for motor
                As the motor is continously on I'm thinking q310 has failed..
                The microprocessor seems to be working as all the unit is working
                Radio.
                Cd
                And tape
                .if I short pin 2 to ground on cn309 and motor turns off does this mean q310 is faulty
                • R_J
                  • 9556
                  Q310 controls the motor circuit on the tape deck, if bypassing Q310 by shorting cn309/pin2 to ground turns off the motor, that means the circuit on the tape deck is working like it should, this does not mean that Q310 is defective.
                  You can also check the voltage on CN309/pin2 when you place the whole machine in standby, this should also turn off the cassette deck motor by turning on Q310 causing pin2 to go low
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    Thanks I'll try this later .
                    If the motor does not turn off when shorting pin 2 to ground is q310 the culprit
                    • R_J
                      • 9556
                      No. then it is likely Q1316 shorted e~c or Q1314 is bad.
                      I have see other tape decks that use touch controls for there operation, and they keep the motor running, as that is what makes this type of mechanism work.
                      If the mechanism engaged before the motor started it would not have the power or momentum to engage the mechanism.
                      If the motor was not running, when you pressed PLAY there would need to be a delay for the motor to start and get up to speed before the plunger activated the mechanism to engage the tape heads/pinch rollers.
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        But this was not happening before. So something is very funny
                        I'd expect the tape motor to stop when selecting another input
                        It does not make logical sense to always keep it running even when the radio is selected
                        I've never seen a transistor with this part number
                        B1GDCFGH0002
                        Do you know if there is an alternative please .thanks
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          Can't find anything B1GDCFGH0002
                          Hi
                          I can't find information on B1GDCFGH0002
                          What would be a suitable replacement please thanks
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            Re: Can't find anything B1GDCFGH0002
                            It's a transistor I'm guessing for a panasonic stereo
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              Thanks but need a replacement
                              Do you know what is an alternative please
                              • R_J
                                • 9556
                                They are sometimes refered to as digital transistors, they have internal base bias resistors, look at the number on the part itself.
                                Measure the internal resistors
                                • lcdcaps1
                                  • Oct 2011
                                  • 322
                                  I'll have a look but can't read the writing on the part
                                  How would I know for sure if it is Q1316 or Q1314
                                  • lcdcaps1
                                    • Oct 2011
                                    • 322
                                    Ok so after a lot of cleaning, I managed to get the writing on the transistor
                                    for B1GDCFGH0002
                                    The writing on the chip is
                                    33 07
                                    Can anyone tell me which transistor this is and what replacement will be fine
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      So i measured the emitter and collector on Q1316
                                      i got 0.8 ohms
                                      so how do i know if Q1316 is bad and so is Q1314
                                      i can buy q1316 easily but q1314 is a pain as nothing is coming up
                                      • lcdcaps1
                                        • Oct 2011
                                        • 322
                                        i shorted pin 2 to ground on cn309
                                        the motor did not turn off
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • Joho
                                          HP PRODESK 600 G2 DESKTOP MINI starting, no picture, fan only spinning faster and faster
                                          by Joho
                                          Hi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
                                          Model: HP ProDesk 600 G2 Desktop Mini
                                          Product No: Y3J22EC#ABD
                                          BID=15WWP3ET6**#SABD#DABD
                                          Serial: CZC632BBCJ
                                          First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
                                          When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
                                          Without CPU I get "CPU...
                                          03-07-2025, 09:18 AM
                                          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                          This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:20 PM
                                          HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
                                          09-12-2024, 02:15 PM
