1604 VLZ PRO Mackie mixer schematic / advice please
  • zen
    • 511
    Hi all , this unit has an issue on the back end input board .
    Flexing the board causes cracking & distorted audio .
    Struggling to isolate cause .
  • CapLeaker
    Leaking Member
    • 8293
    Re: 1604 VLZ PRO Mackie mixer schematic / advice please
    figure out on where the problem lies by flexing or poking with a wooden spoon at things or heating up or freezing certain areas. Maybe you could isolate down to an area, then resolder or reflow it. Sometimes you have to totally desolder the offending part, clean the through hole and put it back in.
    • zens electronics
      • Jan 2021
      • 31
      Cheers , but issue is so sensitive .
      Tried heat / freeze aswell
      Most components on the board are SMD types , which are so difficult to access , as ports in the way .
      Absolute nightmare to work on .
      • Longon
        Behringer Pro Mixer DJX-750
        by Longon
        Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
        08-11-2025, 02:17 PM
      • Geeeetarzan
        Mackie PPM 1012 mixer/amp
        by Geeeetarzan
        Hi Folks, I've got a Mackie PPM 1012 mixer/amp that i got dead, no lights. Fuse is internal and is not blown. The power supply powers up without popping the fuse, no smoke no smells.No components seem obviously smoked or swollen. I'm a tube amp guy so i'm fine with high voltages knowing this one isnt that high, and have a decent fluke meter. With no schematic i'm not necessarily in my element. With a schematic and voltages i could chase. Anyone have the schematic? Or is anyone familiar with specific quirks on this one? I was told it was running at the end of a long extension cord outside and died...
        08-02-2022, 07:27 PM
      • Bektronics
        Schematic Digital Audio mixer RCF type M18
        by Bektronics
        Hello dear audio friends.
        I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
        The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
        I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
        Thanks in advance if anyone can help me with this schematic.
        Of course, all information about this digital mixer and possibly references...
        07-24-2023, 06:40 AM
      • Thermaltake
        Yahama mixer PSU difference
        by Thermaltake
        I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
        I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
        And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
        I google a little and found that there is this part number...
        09-17-2024, 11:52 AM
      • Thermaltake
        Power button on Behringer Xenyx 1204USB mixer dead ?
        by Thermaltake
        Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
        I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
        08-16-2022, 03:22 AM
