Bose Soundbar 500 series bios dump request
  • fricosu007
    • Feb 2016
    • 38
    • romania
    Hello guyz ! i got stuck on a piece of BOSE soundbar 500 series with boot loop after latest firmware update, nothing works, uploading new firmware gives an error at the end, i found two eeproms soldered on the motherboard, managed to read them but the w25q128 seams to be empty while the 25q16 looks kinda ok from the data but i am sure there is something wrong with it. Maybe you guys have one around .. would be nice to try and flash your dump onto mine ! many thanks !
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • haitham sharabati
    by haitham sharabati
    Hello engineers 😀,
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    💀 Problem:😅
    08-07-2025, 04:54 AM
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
