Marantz SR6007
  • Fripacks
    • Jun 2021
    • 59
    Marantz SR6007
    I have this amplifier who have Front Right channel defect, I change all transistors, resistors on output transistors. I found little Zener diode short, the location is ZD406, someone have the service manual or the value of this diode?
  • lotas
    • Jan 2016
    • 4608
    • Russia
    Re: Marantz SR6007
    ZD406 - ZENER ZJ4.7B-0.5W (4.7v 0.5w)
    Service Manual Marantz SR6007:
    • unimatrix93
      TV backlight zener diode
      by unimatrix93
      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
      The led strips has 9 6V leds.
      02-10-2025, 12:13 PM
      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
      I bought this from an eBay seller but unfortunately they only had one
      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
      I bought three of from them to also make battery packs with this output power limit in mind
      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
      04-23-2025, 05:50 AM
    • nev1001
      What zener diode might fix the sound on Maestro Mayhem gaming chair?
      by nev1001
      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
      I think an issue could be a zener diode (or capacitor) which has shorted out.
      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
      04-17-2025, 05:09 PM
    • Vincenzo2
      Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
      by Vincenzo2
      My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
      Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
      I put some pictures here to show that it is labeled "M7"....
      09-07-2023, 07:43 PM
    • hobostove
      Corsair RM1000e - Help identify 5VSB Zener diode
      by hobostove
      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
      There's a 22ohm resistor that's melted and open, but it still has the bands.
      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
      It looks like the diode connects the source and drain of a TNY284...
      03-27-2025, 02:25 PM
