Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
  • magneh
    • Apr 2014
    • 610
    • Portugal
    Hi
    Long story short, Harman Kardon Aura Studio 2 speaker, no power.
    Disassembled, found burned IC, maybe the 5V regulator? not sure
    No schematics
    IC marking: 225S2 (see pic)
    Board ref: 40-KS320U-PSK2G
    Thanks for any help!
  • R_J
    • 9594
    Re: Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
    It is a EUTECH EUP3484 buck regulator
    • magneh
      • Apr 2014
      • 610
      • Portugal
      Thanks R_J!
      Will replace it and try to fix the speaker
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Dont forget to check the capacitors around as well
        • magneh
          • Apr 2014
          • 610
          • Portugal
          So I got the IC to replace, it was indeed the 5V regulator IC.
          All caps measured OK, I checked the values of each pin before and after replacement and values were all OK.
          So Ive connected power to it, but still no joy, unit does not power up.
          Now I have 5V on the left coil, but the smaller one on the right, which I think is the 3.3V , has 0V.
          The IC with ref. 336K2 has 19V at the 2nd pin, but 0V at all other pins.
          Pin 3 is output as its connected to the coil.
          Googled "336K2" did not give me much result, how can I find the datasheet for this one also?
          No shorts found on this IC either, only pin4 which is ground.
          Any hints?
          Thanks!
            • 31218
            https://cdn.badcaps-static.com/pdfs/...99bed2196e.pdf
            • R_J
              • 9594
              On that ic, Pin2 is the Vin, but you will not have any output if the EN (enable) pin is 0 volts, I suspect the regulator is not being told to turn on. If the 5v regulator went bad, it may have damaged other components it supplies, If it supplies standby for the main microprocessor, it may have been damaged? Try and trace that 5v line and see what it supplies, it may be something like a open 0Ω resistor that feeds a critical ic.
              • funky2x
                Harman kardon onyx studio 7 Smd code
                by funky2x
                Cant find what smd code Y0DVA.
                sitting in Harman kardon onyx studio 7. Appreciate any help.
                05-29-2025, 03:44 PM
              • PowellSkier
                Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                by PowellSkier
                A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                06-17-2024, 11:43 AM
                HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
                This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                09-06-2024, 06:00 AM
                MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook Z16 HX Studio Specification for Upgrade or Repair
                This specification for the MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-052 boardview and Z16 HX STUDIO B13VGTO-052 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-07-2024, 06:38 AM
                MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook Z16 HX Studio Specification for Upgrade or Repair
                This specification for the MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-051 boardview and Z16 HX STUDIO B13VGTO-051 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
