Onkyo tx-sr577 just some questions
  • reassor
    • Apr 2021
    • 181
    • Poland
    So i have HK avr 230 as backup (very good condition didnt even look at its bias)
    But my main is TX-sr577 im using it as stereo amp.
    Wierd thin when i looked inside i saw 2 main transistors had cut middle legs and when you set it to 6+ ohms its gets hot like crazy
    For me its ok i need stereo with 4ohms (cantons) yet im curious.
    Some while ago it started going into protect - debug said V so over voltage.
    Q1: do you set bias in 4 or 6 ohm mode (i guess thats 2 transformer modes for this biach)
    Q2: it was shutting donw as overvolt when i was using spdif as source (DSP?)
    Q3: does any 1 love me?
  • petehall347
    • Jan 2015
    • 4451
    Re: Onkyo tx-sr577 just some questions
    what do the instructions say ?
    • kodiac
      rx-750 pioneer stereo memory
      by kodiac
      I have rx-750 pioneer stereo and the stored radio stations in the memory does not stay in the memory very long.
      Does anyone know where the memory is located in this stereo and how it is powered up?
      It does not have a battery backup.
      Does the memory use a capacitor for its power supply?
      thank you
      11-22-2025, 05:49 PM
    • MotherTeresa
      Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
      by MotherTeresa
      Hi.
      I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
      Regards.
      09-20-2025, 12:09 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • mikkele86
      Luxman R-5045 - Cant adjust current bias
      by mikkele86
      Hello good people of badcaps.
      im back with another question
      Im trying adjust the current bias accordingly to the manual, but my meter is showing the same value no matter whatever position VR-804a/VR-804b is in.
      DC bias is adjusted and is working as intended.
      Is my settings on the multimeter wrong ? or should i look for a bad component
      note: all transistor are new
      Picture from manual
      My measurements
      04-24-2024, 10:19 AM
