Crate PowerBlock 150 very low volume
  • Camarada78
    • Jan 2021
    • 28
    • Brazil
    I have a Crate Powerblock cpb150 on bench right now.
    It has very low volume, although everything appears to be working fine.
    The powersupply (a common issue on this unit) is giving me all the juice needed but i still have low volume.
    It uses a lot of 072 as preamps and a tda8920th as the class d poweramp.
    The class D is receiving the +/- 25 volts as it should.
    The volume is low either on 8 ohms, or 4 ohms stereo and on the heaphone amp as well.
    I think its a preamp issue, but i dont know. i'm not used to tda8920th, dont know how they should behave.
    If anyone could give a light... i would be thankful.
    Thanks in advance for the help.
    • 31214
    Re: Crate PowerBlock 150 very low volume
    TL07/08 type op-amps are always a good place to start.
    • karthur
      Vizio D65x-G4 Volume changes on its own
      by karthur
      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
      06-05-2025, 08:13 AM
    • crackedprint
      Sony HCD-HX80R Amplifier Volume Control Problem
      by crackedprint
      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
      I have tried a Cold Reset as per the service manual.
      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
      I have looked all the way through the service manual and tried many online...
      01-21-2025, 12:18 PM
    • BigOof
      Marantz SR5007 popping on volume change and mute in Direct Mode
      by BigOof
      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
      12-12-2024, 06:15 AM
    • Storyteller12
      Samsung Soundbar Q900T Cuts Off if Volume above 30
      by Storyteller12
      I have this soundbar and when I turn it on it works until I turn the volume above 30.
      Then the display show “PROT” protection and shuts off.
      I can turn it right back on and it works until volume hits 30 again.
      There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
      I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
      It will play fine for hours with volume...
      03-21-2023, 12:31 PM
    • dicky96
      What 'class' is this Hill Audio DX3000 Amplifier?
      by dicky96
      Hi guys, this is general query really
      So I have a Hill DX3000 3KW audio amplifier here.
      It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
      I was wondering what class this is. It doesn't fit the description of class A.
      It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
      I looked for 'class A push pull' but that didn't tell me anything either
      05-04-2022, 04:20 AM
