Sony MDR-DS6500 headphone repair
  • korikmate
    • Mar 2021
    • 8
    • Magyarország
    Hello experts,
    I have a Sony MDR-DS6500 headphone. It is charging, the charging stops when charged up, but it does not turn on, there is no life sign if pressing the on/off button.
    Battery replacement is already done, the problem still exists.
    First of all I would be happy if I could get a service manual for this, maybe from anyone who has access to Sony service manuals.
    Second I would be glad If you could give me advices where to start searching the fault.
    I have already made some investigations:
    • Battery is OK
    • Battery connection is goes straigth from left earphone (battery board) to right, there is 3,7v at output of this board.
    • There is 3.7v where battery board connects to the main board where the ON OFF switch is
    • ON OFF switch is switching as it should, and there is 3,7v voltage
    • There is a green wire from battery board to main board says "PG". Should be anything there? There is no voltage. What is this?
    Thank you!
  • R_J
    • 9569
    Re: Sony MDR-DS6500 headphone repair
    At first look the wire strands from Batt+ might be shorting to PG which could be Power Ground (it does go to ground, correct?). Check the 000 (0Ω) jumper resistor. What are the markings on IC103?
    • korikmate
      • Mar 2021
      • 8
      • Magyarország
      Hello, and thank you for the helping hand!
      That red wire is my power injenction, i have already made it better looking, but there was no short... Funfact If I press the power on button, then a peak of voltage (just for 1-2sec) represents on green connection (PG) 1 V. If I hold the button pressed, it disappears, but if I pressing agai and again then I can like pumpping it.... Is this normal?
      IC103 is TK63101SCL-G SOT23-5 mosfet. At that mosfet I have the voltage at the track where the resistor is (same as battery + voltage, 4,2V) and from there, there is nothing. If I push the button, then 2.6 V voltage represents at upper left leg on the picture, but it disappears when I release power button. Also when the button is pressen, the third pin to right I can measure 3,6 Volts.
      • korikmate
        • Mar 2021
        • 8
        • Magyarország
        Originally posted by korikmate
        hello, and thank you for the helping hand!
        That red wire is my power injenction, i have already made it better looking, but there was no short... Funfact if i press the power on button, then a peak of voltage (just for 1-2sec) represents on green connection (pg) 1 v. If i hold the button pressed, it disappears, but if i pressing agai and again then i can like pumpping it.... Is this normal?
        Ic103 is tk63101scl-g sot23-5 mosfet. At that mosfet i have the voltage at the track where the resistor is (same as battery + voltage, 4,2v) and from there, there is nothing. If i push the button, then 2.6 v voltage represents at upper left leg on the picture, but it disappears when i release power button. Also when the button is pressen, the third pin to right i can measure 3,6 volts.
        I have made a drawing. The YELOW only measurable when I press again and again the button, as I said before. The ORANGE voltage only measurable when hold the on off button, and the red is measurable always.
        • R_J
          • 9569
          On some power supplies PG stands for Power Good. so that might be a line to tell something else that the voltage is good. I could not see where it went in the original picture, it looked like it went to ground, but now I see it is on its own.
          • korikmate
            • Mar 2021
            • 8
            • Magyarország
            IDK how I missed that but there is a short circuit from the outout of that mosfet ritght to the VM pin of IC102. How could I identify what is shorted there? Simply measuring the capacitors is not right for obvious reason. But how then?
            • korikmate
              • Mar 2021
              • 8
              • Magyarország
              The short is gone there, I put out caps and one of them was faulty I guess. But the problem is still it does not turn on
