Dbx 286 repair
  • falcontech
    • Oct 2013
    • 470
    • italy
    Re: Dbx 286 repair
    the LEDs do not move, it will be a little difficult to find an oscilloscope, if they do not have a high cost I could decide to replace them all, maybe one at a time in order to identify the culprit, you could tell me from the photo which are the opamps thanks
    • CapLeaker
      Leaking Member
      • 8147
      Re: Dbx 286 repair
      the pictures aren't clear enough to see what is printed on the IC's. Sorry. Download the schematic and the block diagram. You successfully eliminated the problem being at the input stage.
      The problem is either the switches (not giving any audio to the compressor) or between the compressor stage and the clipper.
      There aren't that many IC's on the board anyway... if you wanted to shotgun it...
      • falcontech
        • Oct 2013
        • 470
        • italy
        Re: Dbx 286 repair
        below is the description of the ic on the board, i have had a look and there are several op amps, i can't find that 4305 i don't understand what it is
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Re: Dbx 286 repair
          Do the "4305" chips have any other markings? 4305 sounds more like a production code (week 43 of 2005). Feel free to cross-check with the schematics I linked on page 1 here.
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • falcontech
            • Oct 2013
            • 470
            • italy
            Re: Dbx 286 repair
            i've found it's...https://cdn.badcaps-static.com/pdfs/...26bacfc613.pdf
            • falcontech
              • Oct 2013
              • 470
              • italy
              #26
              Re: Dbx 286 repair
              which one do you recommend to start with?
              • CapLeaker
                Leaking Member
                • 8147
                Re: Dbx 286 repair
                I still think you should get or borrow an oscilloscope or something in order to see exactly what is going on inside.
                BTW... on the block diagram there is a 6.5mm audio jack called insert on the back. Work and lube that jack a bit. If it isn't making any contact, nothing works on the compressor side either.
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #28
                  Re: Riparazione Dbx 286
                  the insert is ok, possible there is no other way than with the oscilloscope? what do you mean by something like that?
                  • CapLeaker
                    Leaking Member
                    • 8147
                    Re: Dbx 286 repair
                    you need some sort of a probe, either visual like an oscilloscope or audible like high impedance audio probe of some sort.
                    • falcontech
                      • Oct 2013
                      • 470
                      • italy
                      #30
                      Re: Dbx 286 repair
                      can you give me a link for the audio probe, to understand what it is
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #31
                        Re: Dbx 286 repair
                        ok then I will do so, in input I will put an audio signal, in output an amplified speaker with the hold connected to the ground output of the jack and with the signal I will go to inspect the inputs and outputs of the ICs. Tell me if this could work
                        • CapLeaker
                          Leaking Member
                          • 8147
                          Re: Dbx 286 repair
                          its better than nothing.
                          • falcontech
                            • Oct 2013
                            • 470
                            • italy
                            #33
                            Re: Dbx 286 repair
                            between today and tomorrow I will do this test, must it be done with the processor active or deactivated?
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #34
                              Re: Dbx 286 repair
                              https://sound-au.com/articles/troubleshoot2.htm
                              • falcontech
                                • Oct 2013
                                • 470
                                • italy
                                #35
                                Re: Dbx 286 repair
                                Good morning
                                I give you updates, unfortunately with the improvised probe I could not understand much, on some ic I had both the input and the output, on some I had a distorted signal on others nothing, I decided then (given the low cost) to replace them all, at the moment I have arrived the 4580r and 074c I have replaced them and nothing has changed, the Lm339dg must arrive, the other two the that 4305 and lm3046m I could not find them in Italy, lm3046m is on ebay but it comes from china and I don't dare to imagine when they will arrive ... does anyone know if there is an equivalent? I couldn't find it and apparently it's out of production. As for that 4305 the only one to have it in order with arrival in June is mouser waiting for some news thanks
                                • falcontech
                                  • Oct 2013
                                  • 470
                                  • italy
                                  #36
                                  Re: Dbx 286 repair
                                  Good morning
                                  I close the discussion as resolved, I waited a month for them to arrive, the problem was THAT4305, I ordered them from the parent company as a free sample and they arrived only yesterday, after having replaced all the chips on the board in the end they were those. .. the only thing I do not know is if only one was defective or all three because I replaced them all from the rush. That corporation sent them to me as a free sample because they are really hard to find. Thank you all for your help
                                  • CapLeaker
                                    Leaking Member
                                    • 8147
                                    Re: Dbx 286 repair
                                    good job!
                                    • Flaku_34
                                      Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                      by Flaku_34
                                      Introduction:
                                      Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                      04-18-2024, 12:47 PM
                                      Acer Predator PT315-51-7815 Notebook Specification for Upgrade or Repair
                                      This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 11:44 AM
                                      Acer Predator PH317-51-7815+Helmet VR Notebook Helios 300 Specification for Upgrade or Repair
                                      This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 06:45 AM
                                      Acer Aspire A515-51G-7915 Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-51G-7915 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-51G-7915 boardview and A515-51G-7915 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:00 AM
                                    • ohren
                                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                      by ohren
                                      Hello!
                                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                      Measured voltages with no load:
                                      After rectifier diodes
                                      12V: 6.17 V
                                      5V: 5.67 V
                                      Secondary transformer pins AC measurement (really don't know if this says anything)
                                      12V: 2-2.5 V
                                      5V: 1.04 V
                                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                      03-18-2023, 10:33 AM
