Both right channels dead on dual deck JVC KD-W110 cassette player
  • JimBanville
    • Aug 2020
    • 118
    It's not the cables. Lol. The audio and LED meter for the right channel from both decks shows no signal. Can someone please tell me what to check first? I went ahead an reflowed the solder on most of the IC's. No change. Thanks!!!!
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Both right channels dead on dual deck JVC KD-W110 cassette player
    most likely the record switch needs cleaning
    • JimBanville
      • Aug 2020
      • 118
      It doesn't have a record/play switch.
      • redwire
        • 3906
        Is there a schematic/service manual for it? Can you cross-record, that is from R ch on one deck to the other? Just to see if there is internal R ch activity, compared to Line Out.
        No R ch in both decks likely means the REC-PLAY switch circuitry or further downstream is the problem. If it's only one channel in one deck, easier to track down.
        I would go to the tape head preamps IC801, IC802 and confirm there is signal output there.
        Wild guess is after those tape-head pre-amp IC's is the electronic switching CD4066B's IC803, IC804 which I would suspect.
        Write down DCV measured at their 14-pins. It's easy to see the R and L circuits, take comparison readings between channels, to see if a mux shorted in the IC.
        • JimBanville
          • Aug 2020
          • 118
          Sorry but I don't have the schematic. Do I need to have a tape playing to test those IC's? Thanks!
          • JimBanville
            • Aug 2020
            • 118
            I don't know how I could cross-record from one transport to the other. I suppose I could de-solder the L/R record head wires and reverse them on one transport?
            I just connected a source to the L/R inputs and pressed record without a tape inserted. Both LED meters moved and I got audio from both L/R outputs, if that means anything.
            • JimBanville
              • Aug 2020
              • 118
              Here are the voltages I got from IC 801 & IC 802 (results were very close) from pin 1 to pin 8...
              1.3 & 1.3
              .8 & .7
              5.3 & 5.5
              13.6 & 14.3
              0 & 0
              4.5 & 5.4
              .7 & .7
              1.3 & 1.3
              • JimBanville
                • Aug 2020
                • 118
                Here are the results of IC 804 and 803...
                9.7/9.7/9.7/9.7/.4/.4/0
                13.2/12.7/12.7/9.7/9.7/9.7/9.7
                9.7/9.7/9.7/9.7/12.7/12.7/0
                13.2/.4/.4/9.7/9.7/9.7/9.7
                • JimBanville
                  • Aug 2020
                  • 118
                  Those figures above are arranged where the first number on the first line is pin#1. So it's at the top left corner of the chip as viewed from the bottom of the pcb board. The figure below that pin #1 figure is the first pin on the bottom row of pins. The rest of the figures are arranged in the order in which they appear based on the physical layout of the chips.
                  • redwire
                    • 3906
                    Still a little confusing on the pin numbers, I take it to be:
                    Code:
                    CD4066	IC804	IC803
                    Pin 1	9.7	9.7
                    Pin 2	9.7	9.7
                    Pin 3	9.7	9.7
                    Pin 4	9.7	9.7
                    Pin 5	0.4	12.7
                    Pin 6	0.4	12.7
                    Pin 7 GND 0	 0
                    Pin 8	9.7	9.7
                    Pin 9	9.7	9.7
                    Pin 10	9.7	9.7
                    Pin 11	9.7	9.7
                    Pin 12	12.7	0.4
                    Pin 13	12.7	0.4
                    Pin 14 +VDD 13.2 13.2
                    Sometimes a bad IC will give a bad DC voltage on it's pins.
                    The DC voltages look OK. If you have a scope or signal tracer, going through the audio path will be the fastest way to troubleshoot. What do you have?
                    You can try Record as well, see if the R ch makes it to tape.
                    What is the part # on the head preamps IC801, IC802? Although the voltages look pretty matched between channels.
                    • provider10
                      nad 6050c cassette player
                      by provider10
                      Hi
                      I don't know if I can ask this. Does any member who might have a scrap NAD 6050 cassette player as I am looking for the plastic base that the heads fit on
                      Regards
                      James
                      11-25-2024, 08:36 AM
                    • dustfilledhobo
                      Kenwood KX-56CW Duel Cassette Deck Repair
                      by dustfilledhobo
                      Hello!
                      I'm trying to fix my Kenwood KX-56CW dual cassette deck (seen in the picture below).
                      Everything functions as it should except that the motor for tape deck B plays back extremely fast (tape deck A functions properly). I've located the two trim pots on the board that control the speed of deck B and they were only able to bring the speed down a little bit. I was able to find a schematic online (attached) with suggested voltages, so I measured the board while playing a tape in deck B (as per the instructions on the schematic). Some voltages were...
                      04-11-2021, 11:52 AM
                    • mikey5791
                      Sony CFS-5000S radio cassette player no FM reception
                      by mikey5791
                      Hi forum members,
                      In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                      Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                      I opened the casing inside and checked for any dry solder, burned component or loose wires...
                      02-24-2023, 03:48 AM
                      MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                      This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                      09-06-2024, 05:30 PM
                    • Nevillet
                      Denon DR-M10HX Cassette Deck Servicing Help
                      by Nevillet
                      Hi All,
                      I have an old Denon DR-M10HX cassette deck and want to service it.
                      I have aquired some test tapes and I have a scope. When I connect the scope to the L&R line level outputs I see a great deal of high frequency noise. Equally when I play a 3.5KHz test tape it's hard to see the test frequency through the noise.
                      Any advise would be welcome.
                      05-29-2021, 09:36 AM
