Repairing mini XLR to 3.5mm cable
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    Is it same with colors when I'm creating mini XLR to 3.5mm like on normal XLR to 3.5mm ? I already have 3.5mm on one end of my cable and my current mini XLR on headphones is broken, so I would need to solder a new one.
    And I am planning to buy mogami cable with neutrik connectors and solder new 3.5mm on the one end and on the other mini XLR and that will be my new cable for headphones. But I still want to repair my old cable because only mini XLR is problem, and when I am going to replace it with new one it's still going to be in working condition.
    2nd question.
    And when I'm creating new cable is it better to create mini XLR to TRS or to 3.5mm ? I mean if I solder TRS jack I won't have to use that converter 3.5 to TRS, and there is always converter from TRS to 3.5mm even if I have to use it in some case.
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    Re: Repairing mini XLR to 3.5mm cable
    Anyone have schematics for that 3.5mm jack connector to 3 pin mini xlr. I have yellow red and white wire from 3.5mm jack.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      How about using an ohmmeter and see which wire connects to which contact on the jack connector? Y'know... Logic?
      Wire colours are, for the most part, irrelevant, really.
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 337
        • D12
        Don't know how to use ohmmeter for that :/
        I need some schematics what color goes where on that numbers on on mini XLR there are 1,2,3 labeled on mini XLR.
        • R_J
          • 9634
          Pin1 shield
          pin2 black (right)
          pin3 red (left)
          • Thermaltake
            Brain badcap
            • Aug 2015
            • 337
            • D12
            Originally posted by R_J
            Pin1 shield
            pin2 black (right)
            pin3 red (left)
            I have Yellow, White and Red wire. No shielding, no black wire.
            • R_J
              • 9634
              How are the wires connected on the 3.5mm jack? which wires go to the tip, ring & shield (ground) if you can't use an ohmmeter, I can't help.
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 337
                • D12
                3.5mm jack is factory sealed, the other end of cable where factory mini XLR was got faulty, to be precise cable was faulty, the part where cable is going into connector and I couldn't fix that because of sealed plastic, so I cut it off and got new mini XLR connector, now I just need to solder it.
                I will try to measure with multimeter tomorrow and see which cable is where soldered on 3.5mm jack, I didn't use multimere for some time I think I still remember how to use ohmmeter on it.
                • R_J
                  • 9634
                  Since the cable is between two factory sealed connectors, they could have used any wire combination they liked, there is no standard color coding.
                  One wire will be common to both headphone (-) speaker connection, one wire will go to the left speaker (+) the other will go to the right speaker (+)
                  The common wire is usually connected to the 3.5mm jack shield or ground connection, the other two will connect to the 3.5mm tip or ring connections.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 337
                    • D12
                    I measure with buzzer and this is how it's connected
                    • Thermaltake
                      Brain badcap
                      • Aug 2015
                      • 337
                      • D12
                      Can someone help ?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Does this help?
                        • Thermaltake
                          Brain badcap
                          • Aug 2015
                          • 337
                          • D12
                          Aren't white and red wire for left and right speaker, and yellow ground ?
                          This what you gave me is XLR scheme.
                          I need female mini XLR with 3 pin sheme to 3.5mm male.
                          • R_J
                            • 9634
                            White connects to the ground in post #10, the other two are L & R.
                            • Thermaltake
                              Brain badcap
                              • Aug 2015
                              • 337
                              • D12
                              I have numbers 1,2 and 3 on mini XLR connector.
                              • petehall347
                                • Jan 2015
                                • 4451
                                • United Kingdom
                                https://www.badcaps.net/forum/showpo...1&postcount=12
                                • Califauna
                                  Connecting charger cable causes Sony WH-10000MX2 bluetooth headphones to stop working
                                  by Califauna
                                  I have a pair of WH-10000MX2 bluetooth headphones with a strange problem. Connecting the charging cable causes the headphones to no longer turn on when pressing the power button.
                                  I thought I had 'fixed' this when I took them apart and disconnected the battery for 15 minutes and found as soon as you disconnect the battery they can be powered on and off as normal using the power button. But then the moment you connect a charging or data cable to a charger or laptop USB port, the power button stops working and the can't be turned on again. No response.
                                  The...
                                  02-28-2024, 06:14 AM
                                  HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i5-6500T Specification for Upgrade or Repair
                                  This specification for the HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                  09-12-2024, 03:44 PM
                                  HP 260 G2 Desktop Mini PC (ENERGY STAR) 4405U Specification for Upgrade or Repair
                                  This specification for the HP 260 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC (ENERGY STAR) boardview and 260 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                  HP ProDesk Desktop Mini ProDesk 600 G2 ProDesk 600 i7-6700T Specification for Upgrade or Repair
                                  This specification for the HP ProDesk Desktop Mini ProDesk 600 G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk Desktop Mini ProDesk 600 G2 boardview and ProDesk Desktop Mini ProDesk 600 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i3-6100T Specification for Upgrade or Repair
