Re: Sennheiser Ew100/G2 Wireless Mic Receiver
Thanks for the follow-up.
28 Euro for a simple power supply? Expensive!
Thank you all for your assistance and patience, the wireless microphone has been tried out in public and works perfectly, thank you very muchLeave a comment:
The original costs 28 euros with shippingLeave a comment:
So you are on the border line, 17V instead of 16V maximum per unit safe operating Voltage. That Voltage can go even higher that 17V if your AC line Voltage goes even higher.
I would get the correct power supply for the unit.
Is the original one expensive?Leave a comment:
Power supply connected to the jack without load = 17V
With load = 14.50VLeave a comment:
BTW, did you do this test in my post #50?
"So what is the Voltage at the DC jack on the fuse when the unit is off (minimum load), is it still within the safe operating range of the unit?"
What is the Voltage at the fuse (with ref. to Ground of course) when the unit is turned on?
According to the spec sheet of the unit, the operating Voltage range is from 10.5V to 16V.
So the bottom line is that when the unit is OFF (power supply will see little load) the Voltage at the fuse should not be higher than 16VDC, when the unit is turned on (power supply will see heavier load), the Voltage should not be below 10.50V.
https://www.repairfaq.org/sam/aapsfaq.htmLast edited by budm; 08-17-2020, 11:29 PM.Leave a comment:
As I told you I used another power supply for safety which is Ac / Dc 13.5 stabilized 800mA, and not the original one that is in the picture, I understood that the original power supply when it has no load delivers 19V, for the rest if could you explain me better why I did not understand, it is a bit difficult to understand when I use the translator thanks
BTW, I did not see the picture of the 13V 800mA power supply you are using, I only see the Sennheiser one you show here. https://www.badcaps.net/forum/newrep...reply&p=977380Leave a comment:
As I told you I used another power supply for safety which is Ac / Dc 13.5 stabilized 800mA, and not the original one that is in the picture, I understood that the original power supply when it has no load delivers 19V, for the rest if could you explain me better why I did not understand, it is a bit difficult to understand when I use the translator thanksLeave a comment:
Is'n this the power supply you are using?
https://www.badcaps.net/forum/attach...8&d=1595935465
It is just a simple AC -DC power supply, non-regulated. It will put out 13VDC at 0.250A, at lower current draw the Voltage will be higher. You see 19V when there is no load connected, the output will also vary with the AC line Voltage.
If you want to be safe you can use AC-DC linear power supply that will regulate the output Voltage, you do not want to use Regulated switching power supply since it is noisy.
So when is the Voltage at the DC jack on the fuse when the unit is off (minimum load), is it still within the safe operating range of the unit?Leave a comment:
I put the fuse he indicated to me and everything seems ok, the receiver has been on for about an hour and shows no signs of problems, I tried with a non-original power supply, because its original supplies 19 volts instead of 13,5 as the label states and it worries me a little, do you advise me to buy a new original power supply?Leave a comment:
paradoxically I don't have a 1 amp fuse I have to wait for Monday to buy itLeave a comment:
The bad fuse is rated at 3/4A so using 1A fuse is close enough, 2A will be too high in case we may have active shorts when does not show up when we did the static test on those power supply test points.
So get 1A fuse to try.Leave a comment:
i don't know should i look, in case it would be better by 1 amp?Leave a comment:
TP208 is GND.
Those test points look OK, no really low Ohms readings.Last edited by budm; 08-14-2020, 11:09 AM.Leave a comment:
the original fuse has not yet arrived, and I don't have a classic fuse with that amperage to be able to test, if I try with a 2.0 ampere one, can I do some damage?Leave a comment:
without fuse on the board I have a variation only on TP209 = 0 and on TP229 = 43.7Last edited by falcontech; 08-14-2020, 08:40 AM.Leave a comment:
Tp209=28,1 kohm
tp208=00,5 ohm
tp226=17,47 kohm
tp229=44,6 kohm
tp233=7,19 kohm
tp231=12,96 kohmLeave a comment:
If you cannot really do those tests, you can just try installing the new fuse and see what happen.Leave a comment:
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by litsnsirnI have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....11-19-2024, 11:14 AM
by pulper111Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...-
This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
- Loading...
