I'll try to get this in without writing a book:
Will call speaker with controls speaker 1, speaker 1 works when plugged in but it's low volume and turning volume nob has no effect up or down but speaker 2 does not work in this setup. Speaker 1 will give out the same low sound even if the power nob is turned off so off or on the same low volume. Speaker 2 only works when plugged in the headphone jack on the side of speaker 1 but in this setup no sound from speaker 1 and in this setup you only hear sound from speaker 2 when power nob is turned on and it's a little louder but still don't go very high, the sound is heard thru the speaker, didn't try a headphone on it. So at no time do both speaker work at the same time, I couldn't find much info about this odd situation, I think the caps are original so they are OLD, in the first picture the smaller cap of the two on the right only has .71 volts when board is powered on, do you think this is could be the culprit?
