Korg - Microkorg
  • TimN
    • Dec 2013
    • 8
    Korg - Microkorg
    Enclosed are a couple pictures. We plugged the wrong-polarity power supply (I think) into the keyboard, instantly heard a pop, smelled electronic burn, and the keyboard is now dead. I took it apart and found the blown item. I'm not sure what it is. Can anyone identify this, and let me know if it's worth saving?
    The picture of the blown link or whatever it is shows the legend "C38", and the thing is directly to the left of that. It appears to have popped open, or blown in half, like a fusible link, though I don't think that's what it is. On the opposite side of the board, directly "underneath" the blown device, as shown in the second picture, is a circular item with the number "220" on it. I assume these circuits have something to do with the power supply.
  • R_J
    • 9569
    Re: Korg - Microkorg
    That would be C31 capacitor, 100µf 10v. the 220 is a coil L37 (22µH), it will check as a short, IC5 F1 & FU1 may be damaged
    FU1 Surface mount fuse CCP2E20 184090000
    IC5 IC-S-8520F33MC-BNS-T2(TS) 324023008
    F1 FET CPH6302 304060250
    The wrong polarity power supply should not have damged it as it has a reverse polarity protection diode (D3), unless D3 was/is shorted
    • TimN
      • Dec 2013
      • 8
      R_J,
      Thanks for the quick and detailed response! I thought we did use the correct polarity power supply--the nine-volt center-negative is pretty much the only type lying around. I should be able to bring just the board in to be repaired then, without putting it back together? Can those things be replaced?
      • cmlewis89
        LG 47LB5DF blown power supply board
        by cmlewis89
        Hi folks,
        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
        09-03-2024, 07:50 PM
      • maleksa
        Korg Kross2 Service Manual and LCD pinout
        by maleksa
        The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
        However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
        Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
        From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
        10-11-2024, 05:54 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • swerg
        Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
        by swerg
        Hey everyone,
        I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
        I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
        I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
        06-06-2024, 03:39 PM
      • MrzPdlch
        Blown fuses on Gigabyte GTX 980TI 6GB
        by MrzPdlch
        Hey everyone,
        I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
        Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
        Find some pictures of the actual GPU together with a picture of how it should look like.
        I also wonder whther it might be a problem that there...
        03-10-2024, 04:14 PM
