Denon AVR-X3500H no sound
  • santosh.ns
    • May 2020
    • 3
    • India
    I am facing "no sound" problem with a new Denon receiver AVR-X3500H. There is no sound from any speaker at all. If I start audyssey setup, and at minimum complete first speaker test which is subwoofer level check, then everything works fine as long as it remains ON. The moment I put it in standby or switch off the power supply, then same problem occurs when I switch it ON next time. In other words, I have to perform audyssey setup (till subwoofer level test, at minimum) *every time I power it ON*, otherwise there is no sound. This is irrespective of which input or type (HDMI, digital, analog, auto) I select, and no settings other than audyssey setup can bring back sound. Completing audyssey setup doesn't solve the problem either. Irony is that most of it's 3 years warranty period is still available, but I can't claim it because it was bought in another country (USA). I tried all sorts of resets and firmware updates to no avail. Even took the unit to a local Denon service center, where they tried some s/w upgrades, but that didn't help either. I guess all they did was firmware updates that I had already tried at home. They said main/digital/HDMI board has to be replaced, which is quite costly!
    That is compelling me to try out some component level diagnosis and fixing if possible. I can take some chances in case I have to change the main board anyway. So, caught hold of a copy of service manual for this model from here:
    and did some troubleshooting based on that. After looking into all schematics and symptoms of the problem, I suspected that a signal named MVOL_MUTE driven by the CPU chip to INPUT board is somehow not getting set to high in the beginning after power on (high=unmute, low=mute), and audyssey setup somehow brings it back. I traced it on boards and checked with a multi-meter, and it is indeed confirmed. The concerned signal remains low in the beginning, but it is set to high (3-4V) once I perform audyssey setup and then everything starts working fine. Note that this signal is not used for muting when I press mute button on the remote. It remains high both in muted and unmuted conditions, so I believe it will not interfere with normal muting operation as such. I am thinking of bypassing this signal such that it is driven permanently high instead of driving it from the CPU. Not so sure whether I should try that out, and hence wanted opinions from experts on this forum. I am concerned whether it will cause problems under following scenarios:
    1. Currently, I notice that this mute signal is momentarily made low when switching inputs before it is turned back to high again. Will this cause loud noises or pop and click sounds while changing inputs if I tie it to high? Worse still, can it damage electronics or speakers?
    2. It is made low during standby, but it will remain high even during standby after the planned fix. Will this cause any problems or damage?
    3. Will it interfere with audyssey setup, when I need to do it for actual calibration? Again, can it damage electronics or speakers during setup after the fix?
    Any more insights and/or suggestions are highly appreciated!
  • santosh.ns
    • May 2020
    • 3
    • India
    Re: Denon AVR-X3500H no sound
    attaching the service manual for reference
    • easy_mike
      • 4
      Hi. This reminds me of Onkyo receivers that are known for similar problems. Onkyo receivers also have their HDMI boards replaced.
      The thing is, all these modern receivers have the same input processing (DTS) chip, which is BGA mounted. This chip is overheating and is known to lose connection to board. Sometimes, if chip itself is not fried, reballing helps.
      Check the video and see if you have the same or similar chip on the HDMI board!
      https://www.youtube.com/watch?v=2gfM3eKk0tQ
      • FuzzyOwl
        Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
        by FuzzyOwl
        Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
        Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
        Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
        I've followed the trouble shooting guide, audio check...
        12-05-2024, 11:54 AM
      • dansity
        Denon AVR 1912 no sound
        by dansity
        As a foreword I'm relatively novice with component level audio gear repair. My amplifier stopped producing sound and I currently have no funds to buy a new one so I need any help to repair it. I know "no sound" is one of the most common problem but there were other symptoms so some of you seasoned repairman might able to pinpoint the stuff I have to check. I did download the service manual from manualslib the "no sound checklist" is a bit intimidating.
        So i bought it working. First symptom: speaker protection relays on the audio board were clicking...
        05-06-2024, 10:16 AM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
      • Gumboil
        Denon AVR-X2000 no sound
        by Gumboil
        Good day all
        My first post on the forum, tried to find a introduction page, but couldnt. So thank you for having me here.
        After spending most of the past 2 days Googling and watching Youtube videos, I came across the forum, in the hopes that I could get some assistance with the above mentioned amplifier. As I do most days, I switched the unit on yesterday morning, got the relay clicks as per normal, but no sound from any of the speakers. Tried "Audio Direct' and the same issues there. In a panic state, I did a factory reset, without any luck. Then disconnected all...
        06-08-2025, 02:43 PM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
