Pioneer VSX-323-K firmware problem
  • Tom_x
    • Aug 2018
    • 32
    • Hungary
    Hi friends,
    I have Pioneer VSX-323-K unit, and HDMI switch ic damaged (caused by thunder via set top box)
    I changed hdmi ic EP9442 hdmi is now ok, but no sound. I found other shorted IC, EPF025A micom ic. I can buy this ic, but the main problem, nowhere found flash content for this.
    I can't find any firmware for this receiver even HTP-072 or VSX324
    If someone have firmware for these units, please share with me, i'll try program micom ic, nothing to loose
    thx in advance
    Tom
  • EduCabral
    [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
    by EduCabral
    I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
    While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
    🔧 Details:
    • Model: YT-M06
    • Interface: Pioneer 1
    • MCU: Fujitsu MB89F202
    • Goal: Find a valid .bin firmware file or memory dump from a working unit
    I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
    07-15-2025, 12:26 AM
  • EduCabral
    Help with Yatour YT-M06 Pioneer Interface (firmware or schematic needed)
    by EduCabral
    I'm currently working on repairing a Yatour YT-M06 multimedia interface (used with Pioneer head units). I'm looking for the firmware or schematic diagram to troubleshoot the board, as it's currently unresponsive.
    If anyone has any documentation, tips, or experience with this specific unit, I'd appreciate any help!
    Thanks in advance,
    Eduardo (from Brazil)
    07-09-2025, 11:57 PM
  • Yanleb
    LG 42LV5400-UB doesn't power up, Micom issue
    by Yanleb
    This repair is very challenging. I already made my way to the problem. Please read the complete post before commenting. I need the help from good gurus.
    The power button on the TV set is working, the same for the power button on the remote control. When activated the power LED changes from red to white and the power supply relay clicks. But no image appears, and no sound is heard.
    I already investigated the problem. the Micom chip on the EBR73110104/EBT61520408 main board is the issue. The Micom is IC602 that use the μPD78F0514 (UPD78F0514)...
    01-03-2022, 10:52 PM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • matpod16
    Pioneer VSX-D1011 - turn on problem
    by matpod16
    Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
    09-07-2023, 01:43 PM
