Beolit 15 doesn’t charging battery
  • tehmatix
    • Nov 2012
    • 174
    I need your help with Beolit 15 Bluetooth speaker . Works well as long as the battery is charged, on the application shows the battery level, but connected to the outlet the battery does not charge. Tried to find a schematics on the web , but nothing.
    Any ideas , advices ?
    Thank you
  • madan1
    • Nov 2016
    • 721
    Re: Beolit 15 doesn't charging battery
    I doubt there are any schematics for this outside the Chinese manufacturer... but it should not be that hard.
    Start with the charging port ( micro USB? ). Those are the first thing to fail ( bended pins, broken port, cracked joints, etc. ).
    After that check the charging circuit - usually those are widely available charging ICs, so it will be easy to troubleshoot.
    If the port and the charging circuit seem fine, then just bypass the internal charging hardware with something like this https://www.aliexpress.com/item/32673171044.html ( if the battery is 2s 7.4v )
    • Indium
      • May 2021
      • Israel
      Hello.
      Well...it is a bit late with reference to the publishing date. But I will do my best to answer:
      BEOLIT15 circuitry is based on Texas Instruments chip set.
      In the case of the charger - they used a synchronous switched mode device.
      From my experience - there is a repetitive issue with the design here causing a cascading failure to the switching transistors (which tend to heat up). From this point on - damage is caused to the charger such that it is unable to develop turn-on voltages to charge the battery. Repair may vary from replacement of the transistors only through replacement of the charger controller and supporting environment. Soldering the charger controller requires good soldering skills as this is a VQFN package and there are no protruding pins to solder.
      There is no point turning to B&O for help...tried it many times...but without having a warranty in place they will not help
      There are no schematics either...In the past B&O published exquisite service manuals that facilitated a fix but no it seems.
      • Bigbom09
        Bigbom09 commented
        Editing a comment
        Teach me how to fix this to get my Beolit15 working again? And what is that piece? Where can I buy it?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
