Hafler Amp Output Transister Replacement
  • Baldrick
    • Apr 2014
    • 19
    Hi folks. I've got a Hafler P1000 that has channel 2 with a clipping light on and sounds fuzzy.
    I was going to replace the output transistors and looked up the part number, but the original (IRF9540N) are obsolete. I can get a lot of new variations of the original, but I can't match the specs.
    How important is matching the Drain Source Resistant and Gate Source Voltage?
    From Mouser's website, the original has a DSR of 200 mOhms and a GSV of 20V. I can find a DSR of 200, but the GSV is 10V. Or, I can find a DSR of 117 mOhms and GSV is 20V.
    Any ideas?
    Thanks.
  • petehall347
    • Jan 2015
    • 4429
    Re: Hafler Amp Output Transister Replacement
    what makes you think its the outputs at fault ?
    • R_J
      • Jun 2012
      • 9568
      I agree with petehall, mosfets usually short, I don't see a problem replacing them with the irf9540N (P-Channel) as long as you replace both. the irf540H (N-Channel) have an even lower rds(on)
      I suspect if one of the P mosfets shorted, either R97 or R69 would be open as well, same for the N mosfets, check R92 and R70
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        The IRF9540N and IRF9540NPBF (ROHS) are close enough, you're not running them saturated. However agree with petehall347, I would start the look elsewhere to find why it's clipping - as far as I can tell a bad MOSFET will not cause the clip light to turn on.
        (And yeah having an o-scope would be very fun to debug this...)
        • redwire
          • Dec 2010
          • 3912
          MOSFETS are optimized for high speed switching, not linear audio operation. If you pick a substitute based on RDSon or VGS threshold you're gonna have a bad time. Almost all switching MOSFETs fail in heavy linear mode use. Use the SOA curve as a guide. IRF9540NPbF is still in production anyhow.
          Best to confirm it's not the output mosfets that have failed. It could be something else.
          • truclacicr
            • Apr 2019
            • 327
            • australia
            There is a circuit on pages 16 and 17 of the manual.
            • Baldrick
              • Apr 2014
              • 19
              Thanks all.
              The only reason I was going to replace the transistors is because that's my go-to fix for a bad amp. I've done it before several times, but yeah, the channel was always dead - not clipping.
              I'm great with a soldering iron, but not troubleshooting.
              Any pointers on where to look first? I guessing somewhere in the input stage???
              Thanks.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Chances are without an oscilloscope, you will have to go through a lot of guess, desolder, check, resolder.
                You could try to go through all the transistors one by one and see if any are shorted with an ohmmeter or diode checker.
                Perhaps with some more information, someone can deduce which transistor is bad. Without an oscilloscope and it's very hard to understand sound by typing descriptions out in a message forum, perhaps information can be gleaned from the clip lamp.
                What is the status of the clip lamp, is it constant on, flickering?
                Can you get the lamp to turn off ever? Will it turn off with a shorted input? Specific input voltage or volume level?
                • petehall347
                  • Jan 2015
                  • 4429
                  Clipping
                  Monitors the DRIVE SIGNAL and lights when the drive signal voltage exceeds the maximum level for
                  linear operation of the output MOSFETs.
                  • petehall347
                    • Jan 2015
                    • 4429
                    i would be checking around the op amps .
                    • Baldrick
                      • Apr 2014
                      • 19
                      Thanks folks for all of your help!
                      I printed out the wiring diagram and realized I didn't know much of what I was looking at... but, there are a few things I noticed. There's a row of six transistors on the same heat sink. The first two are the IRF9540's, the next two are IRF540N's, and then there's one each of a LM337SP and a LM317T.
                      From the tiny bit I know, it looks like the last two are the output transistors and the others are farther up the chain. I pulled one of the IRF9540's and it tested bad.
                      So, I'm going to replace the first four and see what happens. These first four btw, look like they were replaced at some point judging by the flux on the board (I got it used). Hopefully, there's not something else wrong that's taking out these transistors.
                      Thanks again all for giving me the confidence to continue. I'll let you know what happens (I'm sure you're all on the edge of your seat).
                      Merry Christmas!!!
                      • petehall347
                        • Jan 2015
                        • 4429
                        LM337SP and LM317T. are voltage regulators
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          /me somehow is feeling a "still doesn't work" post for some reason...
                          /me hopes the feeling is wrong however...
                            "I pulled one of the IRF9540's and it tested bad."
                            Tested bad in what way?
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                              I bought this from an eBay seller but unfortunately they only had one
                              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                              I bought three of from them to also make battery packs with this output power limit in mind
                              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                              04-23-2025, 05:50 AM
                            • CoppellTVRepair
                              Troubleshooting PFC with SPC1012T not raising output
                              by CoppellTVRepair
                              It has been a long while since I posted here to ask anything....hope you can help.
                              I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                              I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                              03-09-2025, 10:38 PM
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                            • mecha1166
                              Copper corrosion? Yamaha HS8S Audio 1 output only
                              by mecha1166
                              OAUD Yamaha HS8S Audio one output only.
                              I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                              08-04-2023, 02:55 PM
