Re: LG Xboom PK5 demo mode..probably
How do you flash the firmware?
This topic has been answered.
Hi thank You for work in this project, I have the same problem, but i do not understand how i make the Firmware on the speaker. I can not do this with lg xboom go. Can somebody help me?Leave a comment:
Nice work tomodachi!
Good to see more useful things getting saved from the dump. Proof that manufacturers don't give half a sh** about the environment and only care to fill up their pockets.
Also, thank you for sharing the firmware here. I'm sure other people will find it useful as more of these demo units are uncovered.Leave a comment:
I also purchased 2 demo units of PK3 but haven't figured out a way to turn demo mode off.
PK3 has a different motherboard design inside. PK5 and PK7 have 64 bit SPI rom chip inside but PK3 don't.
would be good to use them if possibleLeave a comment:
I work for a major retailer which has the demo units for the PK7, PK5, and PK3. If you look at the bottom of the unit you will see SVC CODE: PK3.AUSDEMO
These are firmware modified units from LG which will disables all controls other than "Enhanced Bass", prohibits Bluetooth, and battery operation. I the only way I have seen people overcome these firmware locks in the past is to open a retail unit, dump the firmware, open the demo unit and overwrite the NAND with retail firmware.Leave a comment:
Hey, I m here again with the solution !
Finally found a retail version of PK5 and backed up firmware from it.
did exactly as rcdavi3 mentioned here and result was just as expected.
after reflash unit will work same as retail version.
I m posting here the dump, its ok but belong to an older version.
after reflash unit will work same as its retail version.
Remember to update firmware after reflash, not only will update software, it will also increase volume to about %20
To update firmware you need to install an app to your phone named "LG Xboom"
any questions let me know
Models that work with this dump;
LG Xboom PK5
LG Xboom PK7Attached FilesLast edited by tomodachi; 12-15-2020, 03:10 AM.- Selected Answer
What a waste! I'm sure LG could have easily programmed the Demo mode inside as an additional option. So frustrating to see manufacturers do things like this.Leave a comment:
Any suggestion. I have a pk7 with the same problem.Leave a comment:
haha thanks, I m also a hardware guy myself but gadgets nowadays piss me off with their strange firmware issuesLeave a comment:
Hoping that someone sees this and can get a firmware dump here.
When it comes to firmware, I usually throw in the towel - but that's just me: I prefer to stick to hardware issues only.Leave a comment:
Any chance to find firmware binary file I can reflash ? any suggestions ? I can reflash the firmware to its motherboard.Leave a comment:
Update :
I discovered that speaker s charging circuit working, on mobile application you can see current capacity, now its %100 percent full, but still don't allow me to use it, it turns itself off when turned on. But when connect charger it turns on its ownLeave a comment:
It's possible.
But it wouldn't make sense to hardwire anything. After all, why do that, when you can just take any production floor model, and program a Demo mode to activate by pressing some buttons in a certain sequence or by selecting from a menu. This is what many other modern electronics (like TVs, for example) do, so I don't see why they would try to hardwire anything.
I don't think so, the person I got them from said he has loads of these and they all have same issue, said he bought them from a bankrupted companyLeave a comment:
"Not for sales" might be they are broken waiting to be fixed .Leave a comment:
It's possible.
But it wouldn't make sense to hardwire anything. After all, why do that, when you can just take any production floor model, and program a Demo mode to activate by pressing some buttons in a certain sequence or by selecting from a menu. This is what many other modern electronics (like TVs, for example) do, so I don't see why they would try to hardwire anything.Leave a comment:
This speaker can't be hardwired to work as a demo right ?Leave a comment:
if you have the app https://play.google.com/store/apps/d...xboom&hl=en_GB
im sure if you go into settings there is a update section maybe this will update the firmware?Leave a comment:
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
So the battery is backfeeding the charger and being drained.
How can I prevent...Today, 01:04 PM -
by JohndillHi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
Here are the tested scenarios:
1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
2. With the laptop off, plug in charger (LED says on) & the front charging... - Loading...
