Digidesign Control 24 Fader Problem
  • Teletoby
    • Jun 2019
    • 24
    Hi, i have a problem with a Digidesign Control 24. When i turn the unit on, it works normally as it should. But when it becomes warm, the faders start to make trouble. Sometimes its the first 8 fader bank, sometimes its the second 8 fader bank.
    • 31111
    Re: Digidesign Control 24 Fader Problem
    define "make trouble"
    • Teletoby
      • Jun 2019
      • 24
      oh sorry, i forgot the description! They are jumping around, up and down, sometimes they stuck in place (the motor forces them) and sometimes, when they get touched, the flip to the top, and if touched again, they flip down. The flip up and down happens only on the second (B Bank) the random jumping happened on the first bank (A Bank) It always happens with all 8 faders at once.
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
        HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 800 Specification for Upgrade or Repair
        This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...
        09-06-2024, 06:00 PM
        HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 400 Specification for Upgrade or Repair
        This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...
        09-06-2024, 12:00 PM
