Too much heat from Marantz PM4200/N2B
  • stomanata
    • Apr 2016
    • 82
    • Bulgaria
    I have this amplifier for repair.
    I found scheme for Marantz PM4200/N1B from
    here: https://www.manualslib.com/download/...tz-Pm4200.html
    Heat comes from C4467.
    As i notice it has higher base voltage.
    I move back and back and notice that problem start
    from first transistor after IC AN7062N - A1268.
    On second chanel base ot A1268 has 1.7V, but on chanel
    that produce a lot of heat A1268 has 2-2.1V on his base.
    Where to continue to check for fault?
    Regards
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Too much heat from Marantz PM4200/N2B
    What exactly do you mean by "base" (in each case)?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • stomanata
      • Apr 2016
      • 82
      • Bulgaria
      Base of transistor.
      Emitter, base and collector
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Ah, right - the "C4467" part threw me off. "C" is usually the designator for capacitors, and since you didn't say "one of the C4467's" (because there's two of them, one on each channel), i didn't think it was the marking representing a 2SC4467.
        You could compare the voltages on CN37 and CN38 (see "Idling current adjustment" on page 5 of the service manual), and if one of them is far off (which it may well be), see if you can adjust it to bring it back to where it should be.
        • R_J
          • 9549
          What is the voltage on 1.8µH? If the offset voltage was too far off it would trip the protection, so try what Khron said, adjust the idle. Do you have any audio from the speakers?
          • stomanata
            • Apr 2016
            • 82
            • Bulgaria
            Thanks for reply and support.
            Here is the results:
            1. On CN37 (without heat) voltage start from 1.7 and start to increase with 0.1v (1.8 1.9 2.0 2.1.....).
            At 3.2V i turn off amplifier. Then move to CN38 and turn on amplifier. It show ~0.2V (40 times more
            than normal). No way to adjust it with potentiometer. BTW both pot`s are on middle position.
            With pot on problematic side i can adjust voltage of emiter on transistor A1268 (next to IC AN7062)
            to ~1.9V (it must be 1.7V).
            2. 1.8uH is in parallel with 2 resistor at 100 ohms. So i try to measure voltage over one of both resistors but there is no voltage on idle.
            BTW next to coil there is resistor and capacitor in series. On scheme for PM4200/N2M (my is N1M) both resistors are labeled to be 10 ohms. In this amplifier somebody is added 2 resistor at 22 ohms, may be 3W. See it attach
            3. Yes. There is sound from all 4 channels.
            • stomanata
              • Apr 2016
              • 82
              • Bulgaria
              BTW may be it will be much easyer to add some resistor between pin $8 of AN7062 and
              base of transistor A1268 or may be to increase resistor between emitter of A1268 and +37V line?
              • R_J
                • 9549
                Lets start with the reference numbers, Emitter of a1268 has no meaning, Please use the transistors position, Q349, Q350, Q326 or Q325 ? these are all a1268, you see the confusion?
                If I asked for the voltage on 10, where would you measure it? but if I asked for the voltage on R337 or R338 you would know where to check it.
                As for the adjustment, you are doing it all wrong, If you adjust VR31 You must watch the voltage on CN37
                If you adjust VR32 You must watch the voltage on CN38
                You adjust the voltage on those plugs for 5mV (0.05V)
                • R_J
                  • 9549
                  STOP USING THE PART NUMBERS . use the reference numbers
                  AN7062N is IC31
                  A1268 could be Q325, Q326, Q349 or Q350
                  If you start modifying you will blow up the amp
                  • stomanata
                    • Apr 2016
                    • 82
                    • Bulgaria
                    Ok. Sorry. I didn`t know what will be best option to explain what i check.
                    In fact this part number are not relevant to real PCB due to difference in model -
                    my model is PM4200/N2M, and this schematic is for ***/N1M.
                    But ok - i will use numbers from PDF in attach.
                    So, my idea (rejected by R_J) was to add resistor between pin $8 of IC31 and base of Q325 or
                    to increase R327.
                    About voltages... lets assume that heating part is upper part or this part that has labeled
                    reference voltages.
                    So i don`t have CN*** in this PDF.
                    But i measure increasing voltage on part of scheme that don`t produce heat.
                    Other part (that produce too much heat) has ~0.2V on CN**.
                    Adjusting voltage with VR31 cause very small change of this voltage.
                    And NO - i din`t adjust voltages, because first volgate is not constant (it increase
                    every second) and second voltage is ~40 time higher than 5mV (0.005V) - it is 200mV
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      check bias trimmer
                      check bias diodes
                      check bias transistor
                      check resistors
                      measure voltage across drivers bases .
                      • R_J
                        • 9549
                        Do you have negative 14.5 volts (-14.5v) on IC31 pin 10? and negative 8.2 volts (-8.2v) on pin 18 of IC31 ?
                        • stomanata
                          • Apr 2016
                          • 82
                          • Bulgaria
                          check bias trimmer
                          check bias diodes
                          check resistors
                          Sorry, i`m from Bulgaria and i don`t know what does it mean.
                          May be this is the right side of schematic - Q379, Q371, D373, R359 (0.22 ohm,
                          5W)?
                          About voltages.
                          Yes, i got them. All they are a little bit different
                          1 0
                          2 0
                          3 0
                          4 32.3V
                          5 32
                          6 34
                          7 32
                          8 33
                          9 34
                          10 -14.2
                          11 32.5
                          12 31.1
                          13 34
                          14 32.2
                          15 32.7
                          16 0
                          17 0
                          18 -7.9
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            vr31
                            d331 d333
                            q335
                            q345
                            • stomanata
                              • Apr 2016
                              • 82
                              • Bulgaria
                              Thanks to all for support.
                              There is 2 diodes in series (D331 and D333). May be they use them
                              like Zener diode at 1.4v....
                              So, one of this diodes has problem. I don`t know the right words, but
                              other diodes has ~0.7 voltage loss over it.
                              But 1 diode has 0.98V across it. And this was 0.2V difference between
                              both channels.
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                so are you saying its now fixed ?
                                • stomanata
                                  • Apr 2016
                                  • 82
                                  • Bulgaria
                                  Yes.
                                  2 minutes work and 28-30 oC on transistor and heatsink
                                  Before replacing defective diode with 1 minute work and temp
                                  reach 60 oC.
                                  • petehall347
                                    • Jan 2015
                                    • 4427
                                    • United Kingdom
                                    did you dial in the idle current yet ?
                                    • stomanata
                                      • Apr 2016
                                      • 82
                                      • Bulgaria
                                      Yes. Both sides are ~5mV
                                      All work fine
                                      • astroboypaul
                                        Surface Book 2 Performance Base dead
                                        by astroboypaul
                                        I'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
                                        The tablet when not connected to the base seems to work fine, but:
                                        • When tablet is off and connected to the base, it won't turn on.
                                        • Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
                                        • Charger white light turns on when connected to the base, but base battery and tablet
                                        04-25-2025, 12:40 AM
                                        HP EliteBook x360 1040 G5 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 1040 G5 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G5 + Samsonite Base Boost boardview and 1040 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                        09-06-2024, 09:00 AM
                                        HP EliteBook 830 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 830 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Samsonite Base Boost boardview and 830 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        HP EliteBook 850 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        HP EliteBook 1050 G1 + Samsonite Base Boost Notebook 1000 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 1050 G1 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Samsonite Base Boost boardview and 1050 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
