I have a Dennon AVR57 receiver which is about 10 years old. It only has one set of front channel preouts & hence no A/B speaker switch. It does have A & B surround speaker preouts, and I currently have my new outside speakers hooked up to the B surrounds. This of course has some draw backs like difficult volume control and my neighbors know what movies I am watching
So, since the receiver still works like it's new, and I do not want to replace it I have decided that the best solution is to install a 2 way speaker switch on my front channels. My intention is to be able to listen to the outside speakers only by setting the speaker switch to B speakers with the receiver in 2 channel stereo mode, or to be able to set the speaker switch to A speakers only with the receiver in 5.1 stereo surround when I want to watch movies etc inside. However, I may at times want to run both A + B speakers simultaneously. This is where my concern arises, as I do not want to damage my receiver.
So, my question is would a parallel 2 way speaker switch be my best bet, or should I consider a series 2 way speaker switch?
Any helpful advice would be greatly appreciated!
I am considering a QED SS20 2 way speaker switch.
My basic receiver/speaker specs are listed below if it is helpful.
Receiver Dynamic Power:
190W x 2CH @ 8 Ohms
310W x 2CH @ 4 Ohms
390W x 2CH @ 2 Ohms
Outside speakers are Cambridge rated at 8 Ohms, and inside front channels are Paradigm Reference Series of which I do not currently know the ohm rating for.
.So, since the receiver still works like it's new, and I do not want to replace it I have decided that the best solution is to install a 2 way speaker switch on my front channels. My intention is to be able to listen to the outside speakers only by setting the speaker switch to B speakers with the receiver in 2 channel stereo mode, or to be able to set the speaker switch to A speakers only with the receiver in 5.1 stereo surround when I want to watch movies etc inside. However, I may at times want to run both A + B speakers simultaneously. This is where my concern arises, as I do not want to damage my receiver.
190W x 2CH @ 8 Ohms
310W x 2CH @ 4 Ohms
390W x 2CH @ 2 Ohms
