Receiver Onkyo HT-R570 no sound .
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Receiver Onkyo HT-R570 no sound .
    is tape switch set to source ?
    • RogerioBarbosa
      Rogério Perroti
      • Jul 2019
      • 18
      • Brasil
      Yes, there is a MUTE button on the remote, but it is not changing this line that is always triggering the transistor Q5600 at part5: G5. I'm confused because there is a line called MUTE, which I suppose would be the MUTE line.
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        Originally posted by RogerioBarbosa
        Thank you,Yes, it has speaker test/setup feature, but no sound during the test.
        I think the receiver is muting, because there is a protection circuit that doesn't allow the sound to reach the power amplifiers in case of something goes wrong. I measured the *V at the base of one of these transistors, and it is positive(2,5V), indicating that it is conducting and ground the power amplifier imput signal , after the pre-anplifier.(Q5600 at part5:G5).The problem now is: Why this V at the transistor base? There is a signal called AMUT, I don´t know exatly it means, but could be this signal that is doing the transistor ground the signal that goes to the power amplifiers.
        i would cut the base and see what happens . or i might separate pre from main then inject signal to main . well only if main amp is testing ok current and offset .
        • R_J
          • 9594
          Check the voltage on POFF (page21) These amps do mute while powering on or off, that might have something to do with it?
          Just to be sure you can check the amp offset voltage on JL6600B, all pins should be close to 0 volts
          • RogerioBarbosa
            Rogério Perroti
            • Jul 2019
            • 18
            • Brasil
            I opened the AMUT line and the V at the base of the Q5600 transistor changed from 2.5V to -15V, so the transistor no longer landed the signal, but the sound did not appear.
            • R_J
              • 9594
              This AMUTE is likely a control line that the microprocessor uses to mute the audio when sources are switched etc. so you don't get a pop in the audio when you switch sources. That would be my guess since I don't know the microprocessor's program code.
              • RogerioBarbosa
                Rogério Perroti
                • Jul 2019
                • 18
                • Brasil
                #27
                Ok, tank you about AMUTE. I injected audio into the CD input and placed the oscilloscope in the Q5600 collector and got no signal.I know Q5600 is not driving because his base is with -15V
                • R_J
                  • 9594
                  The conrtrol line must be open and the R6681 is the pullup to the -15 volt line, so AMUT must need to be taken low to un-mute the amp, or in this case taken to +5volts
                  Check the voltage on Q752, and Q751, then check Q703 regulator, It seems to supply Q752 via D702 and R711(47Ω)
                  I think Q793 is a 5.6 volt regulator, it is supplied by the +10VS (from the standby circuit)
                  • RogerioBarbosa
                    Rogério Perroti
                    • Jul 2019
                    • 18
                    • Brasil
                    #29
                    Hi, I am back, and I did not resolve the problem yet. I needed stop thinking in the problem because I did not have much time since the last time that I decided to fix de receiver. I will start thinking in the problem again. and would apreciate any sugestions. Thanks
                    • Stroog
                      • Mar 2021
                      • Brasil
                      #30
                      Hello. I know this topic is a little too old but I have this same receiver and i think it has a problem in this ci (R2A1521RFP). It receives a analogic audio input from dvd or others inputs but nothing comes out. VCC is ok. I found it on aliexpress but before trying to replace it i'm trying to figure out if it is muted or not. It receives a signal from another CI (T5CN5, microcontroler) in pin 51. MUTE. Its a high level 3.3V signal. It becomes high when the receiver is turned on and stayed high all the time. I cant find the datasheet in inet to discover if its active in high ou low state. Anyone here knows anything about this ci to claryfing this form me pls. I dont want to expend 10 bucks and a lot of work for nothing. Thanks in advance.
                      • Stroog
                        • Mar 2021
                        • Brasil
                        #31
                        Sorry Im seeing it now. My receiver is a denon. AVR-391. But its the same IC so i think its all the same. Thanks.
                        • nodols
                          • Jan 2023
                          • 24
                          Did you try change the IC?
                          I'm on the same boat, it seems this IC is in many brands. I saw this on an Arcam, Onkyo, and now you have it in Denon. So I'm guessing this is pretty common.
                          I believe I've read it from somewhere that logic high on pin51 is muting this IC. In your case it's probably the processor is sending a mute signal to this IC, and might be an issue somewhere and not this IC.
                          • madan1
                            • Nov 2016
                            • 719
                            • Bulgaria
                            #33
                            If you have an onkyo, denon, pioneer and probably more from that era ( 2005-2015 ) first check if your model uses the defective texas instruments DSP chips.
                            • ai.need.help
                              Onkyo TX-8050 AV-Receiver no sound
                              by ai.need.help
                              I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                              It doesn't play music. There is no real output from:
                              pre-out
                              amp-out A and B
                              phones out
                              The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                              I tested with analog-input, usb and radio.
                              I know that there is a common problem with...
                              12-20-2022, 05:54 PM
                            • CDNBrewer
                              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                              by CDNBrewer
                              Hello Everyone,
                              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                              Symptoms:
                              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                              • I swapped the Left and Right surround
                              08-05-2025, 09:29 PM
                            • JRade
                              Audio video receiver KENWood KR-V990D,no sound
                              by JRade
                              When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                              The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                              I replaced the capacitor C303/0.047F, nothing changes.
                              I'm asking for help, what should I do next?
                              Thanks in advance!...
                              08-05-2025, 10:23 PM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • Sisko
                              Onkyo-593 No power and now clicking sound
                              by Sisko
                              Hi all!!
                              Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                              10-03-2025, 02:18 PM
