Re: Another Yamaha
Thats strange? what are the voltages on the input. It was an all plastic 7912 correct?
Another Yamaha
Re: Another Yamaha
Getting
0.9v 0.6 and -0.02v off the new 7912Leave a comment:
Re: Another Yamaha
Weired, I now have 8-10v on the chassis with just the negative lead on it, getting 0v on the new 7912Last edited by No1baggiesfan; 02-13-2019, 12:30 PM.Leave a comment:
Re: Another Yamaha
O.k.You DO need that -12volts, so it might be a pain to trace the fault , but it is starting to look like a bad op amp ic?
After closer inspection that -12 goes to quite a few placesLeave a comment:
Re: Another Yamaha
Wife's taxi, lol, I will have a look in the next hour, ty R_JLeave a comment:
Re: Another Yamaha
So what is the voltage on the 7912 now? If it is still low there must be something loading it down. or it could be the cap (C1088) on its output is bad.
-12 volts supplies VIDEO (10) board, unplug CB383 and see if the -12v comes up.
-12 also supplies one side of the relays on (page 141)
The -12 also goes to the op amp ic's on (page 137) and elswhereLast edited by R_J; 02-13-2019, 10:48 AM.Leave a comment:
Re: Another Yamaha
Installed new 7912, still no joy ��
PS value still fluctuating but not as bad: 129-135/129
Still getting ps prt 135 h error
Still no standby ledLast edited by No1baggiesfan; 02-13-2019, 08:01 AM.Leave a comment:
Re: Another Yamaha
https://uk.rs-online.com/mobile/amp/...ators/6869748/
Min order is 10 but free shipping, mouser wanted £5 to ship 1, crazy.Leave a comment:
Re: Another Yamaha
I hope it does fix it, I can't really see anything else that would cause the problem.Leave a comment:
Re: Another Yamaha
Ok, thank you very much for your help and your time R_J you are a legend.
I will now go and shop lol, I will update when I get it installed
Thank youLeave a comment:
Re: Another Yamaha
It is an all plastic case, correct?
It does'nt need to be a KIA any xx7912 should be ok, It is a total plastic case to220, so you should replace it with the same type. Most to220 have the metal tab exposed so when monuted it would short to the heatsink
The tab is connected to the input pin so it must be isolated from the heatsinkLast edited by R_J; 02-09-2019, 03:21 PM.Leave a comment:
Re: Another Yamaha
Having trouble finding those here in the U.K. ��
Does it have to be an exact KIA7912P or can it just be a 7912 negative 12v TO-220 ?Last edited by No1baggiesfan; 02-09-2019, 03:03 PM.Leave a comment:
Re: Another Yamaha
Yes, replace it, be sure to get a 12 volt negative regulator 7912Leave a comment:
Re: Another Yamaha
I guess the next step is to replace it and see what happens ? Or is there more to check ?
Quite a lot going on inside there, it's more complex than I expectedLeave a comment:
Re: Another Yamaha
I tested across each, sorry, it was -18 ffs
Ok, each to ground:
C1076 -18.74
R1238 -18.77 and -20v other sideLeave a comment:
Re: Another Yamaha
C1076 18.75v
R1238 1.4v
It was a suggestion from someone else, as they were 5v regulators.Leave a comment:
Re: Another Yamaha
Of course not, they are different voltage regulators (see schematic) IC334 +5 volt 4 pin regulator. IC457 3pin +5 volt regulator, again not the same.
How would you check ic102 out of circuit? do you have an adjustable bench power supply?
Look at the data sheet for a kia7912 and you will see what is inside.Last edited by R_J; 02-09-2019, 02:09 PM.Leave a comment:
Re: Another Yamaha
should the voltages of ic334, ic333, ic457 be similar?
Should I take out ic102 and test I out of circuit ?Last edited by No1baggiesfan; 02-09-2019, 01:58 PM.Leave a comment:
Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
what is wrong with your PC in just seconds. It saves you time and money.
Our new and improved design...-
Channel: Schematics and Boardviews
11-01-2024, 06:29 AM -
by SinnyoneHi all,
This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
I have searched through the forums and have not found anything about my problem. So,...-
08-30-2023, 08:35 AM -
by nzphilI have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...-
by jjneI have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
At first I thought it was either a speaker relay or the DSP, but I don't think...-
- Loading...
