Monitor Audio RSW-12 - crackle and popping sound
  • dobrykamil
    • Jun 2013
    • 63
    Hello
    I've got above model and it works in general, but instantly after powering on, subwoofer produces very annoying crackle and popping sound. I believe this is another, common issue with this model. Most information on the internet is regarding hum, buzzing sound etc. caused by dodgy +15V, -15V rail caps.
    I've managed to repair different MA subwoofer with exact symptoms in the past - BXW10. Problem is, amplifier for RSW12 comes with two IR2110 mosfet drivers working in full bridge circuit.Long story short, I've replaced both bootstrap caps (that was the case with BXW10) but it didn't help at all. I don't have SM yet, but I've emailed MA support team, so hopefully they'll come back to me soon. I believe problem is caused by one of the caps, because popping sound goes away (not entirely, becomes less frequent) once the unit warms up a bit.
    Has anyone came across with this problem before?
    Cheers
  • petehall347
    • Jan 2015
    • 4440
    Re: Monitor Audio RSW-12 - crackle and popping sound
    popping is most times transistors
      master hoarder
      • May 2008
      • 12175
      That's a good clue there.
      Heat usually affects two things the most: solder joints and electrolytic capacitors. When electrolytic capacitors are made warmer, their ESR spec improves. So it's possible you may have more bad caps in the unit, even if none look visibly bad (not uncommon for caps to go bad without showing it.) Likewise, solder joints inside the unit also get affected by heat, as things can expand and contract from the heat. Of course, it's also possible to have marginal (electrically leaky) transistors, as petehall347 suggested above.
      With that being said, I advise you open the unit and inspect all solder joints first. Also take note of any caps that might be located in hot spots, especially small ones - those would be the first ones to fail. While at it (and waiting for MA to reply to you, which I don't think they will, TBH), you should post some pictures here.
      • matyka
        • Jan 2015
        • 179
        • Uk
        I would need some help with my BXW10 produces very annoying crackle and popping sound could you please let me what did you replace it. I don't see any bulging capacitor's.
        Cheers
        • MOSSEP
          Monitor Audio RSW12 - Green light, but no sound
          by MOSSEP
          Hi
          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
          I have already tried replacing all of the...
          01-26-2025, 08:33 AM
          by momaka
          03-15-2023, 10:17 PM
        • proxneo
          Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
          by proxneo
          Dear reader
          I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
          12-02-2023, 09:27 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
