Onkyo TX-NR717 No sound.
  • XgN
    • Apr 2019
    • 7
    • Lithuania
    Re: Onkyo TX-NR717 No sound.
    Originally posted by madan1
    No, do not do anything to the DTS.
    Most likely it is something else.
    For a start check all power rails going to the hdmi board.
    Do you have video output? Is the OSD working? Is the internet radio ( DLNA? ) working?
    Yes, I have tried connecting to a TV via HDMI output and it shows the menu perfectly. Also Ethernet is working and successfully connecting to home network. Also it's reading an USB, playing tracks but even with Pure Audio enabled there is no sound on this setup (USB Input).
    I think someone tried to repair this board - screws are used.
    • madan1
      • Nov 2016
      • 719
      • Bulgaria
      In this case you should start with the board connections.
      See the SM for the signal flow paths.
      Once you are sure all boards are connected properly, you can start checking the power supplies on the HDMI board.
      Try tracing the analog audio to the ADC and DAC. If you have troubles doing this, post some HD photos of the boards to pinpoint you the test points.
      • ai.need.help
        Onkyo TX-8050 AV-Receiver no sound
        by ai.need.help
        I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
        It doesn't play music. There is no real output from:
        pre-out
        amp-out A and B
        phones out
        The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
        I tested with analog-input, usb and radio.
        I know that there is a common problem with...
        12-20-2022, 05:54 PM
      • CDNBrewer
        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
        by CDNBrewer
        Hello Everyone,
        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
        Symptoms:
        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
        • I swapped the Left and Right surround
        08-05-2025, 09:29 PM
      • JRade
        Audio video receiver KENWood KR-V990D,no sound
        by JRade
        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
        I replaced the capacitor C303/0.047F, nothing changes.
        I'm asking for help, what should I do next?
        Thanks in advance!...
        08-05-2025, 10:23 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • Sisko
        Onkyo-593 No power and now clicking sound
        by Sisko
        Hi all!!
        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
        10-03-2025, 02:18 PM
