Pioneer VSX-920 receiver shutting off after 1 minute
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I'm not an audio guy, so I'd like some ideas on this Pioneer VSX-920 AV receiver which shuts off after about 1 minute after startup. The display comes on, everything works, but the set turns off after said time. I am also unable to perform a reset by holding down the "band" button along with the power button - nothing happens. According to the manual, it's supposed to power on and display "Reset?" but it doesn't. Same goes for other button combinations I've come across on the internet, like the ones to display the error codes or force a startup. They don't work either, so it could be a "logic" side issue rather than a "power" side issue.
    I must admit I haven't taken any in-depth measurements, so for now the discussion is going to be rather generic about what could actually cause this. Failed output transistor ? Bad capacitor ? Bad main board (this was my colleague's suggestion, after encountering a similar unit in the past). I've also had a look through the VSX-1020 service manual since it provides more info on some of the service key commands you can perform and the units are similar, but the file is too large to upload so you can search for that yourself, though it's not that relevant.
    Any thoughts from people more vexed in the field of audio amps would be greatly appreciated (I'm more of a TV guy and only know some basics about amps)...perhaps someone knows this to be a common fault with Pioneers or something. Cheers and thanks.
    Wattevah...
  • R_J
    • Jun 2012
    • 9550
    Re: Pioneer VSX-920 receiver shutting off after 1 minute
    During Standby mode, simultaneously press and hold the [PRESET –] and [STANDBY/ON] keys for 2 seconds to
    enter this mode.
    The display will return to the normal indication when no key operation is performed for 5 seconds
    Pressing ENTER key will step through screens
    Reset mode to clear errors
    During Standby mode, simultaneously press and hold the [STANDARD SURROUND] and [STANDBY/ON] keys
    for 10 seconds to enter this mode.
    The display will return to the normal indication when no key operation is performed for 5 seconds.
    Press ENTER to clear error codes
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I believe I tried that and it's not happening - some internal error or something going on....will try it again tomorrow, maybe it's different for the 920 model....
      Wattevah...
      • R_J
        • Jun 2012
        • 9550
        The manual for the vsx-920-k should be used with the VSX-820-k manual I would check the dc offset at ALL speaker outputs, maybe one is off and causing the shut down?
        It could be anything with these amps
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          True that. Strange that it happens after roughly one minute every time...could be temperature-related
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            I contacted a local forum as well and some chap there described a problem very similar to mine: amp runs a couple of minutes then freezes and restarts. He narrowed it down to a bad "DSP", which I believe involves the main board itself since you're NOT replacing just an IC on that, that's for sure...
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              I actually managed to reset the amp and access some of its service menus this morning. Turns out it's somewhere between the 820 and 1020 in terms of key combinations, like so:
              -ENTER and MULTIZONE ON/OFF enters the error count menu where I got DC: 002, OL: 001 and 000 for everything else. I also reset these counters while I was in here and they didn't move up even after the unit power cycled as described, so this is similar to the VSX 1020
              -holding ENTER while powering up the unit enters the "reset" menu. There's also another option in there "D. SAFETY" which is set to OFF and I don't know what it does so I left it like that. I did the reset here as well but didn't change anything.
              -TUNE UP while powering on the unit displays the different versions (again, as described in the 1020 manual): DSP 1.001, MAIN 1.007, SUB 1.207.
              It seems to remember its settings now though, because I noticed before the first reset, the volume would default to -35db or something, but now it stays where I put it because I turned it all the way down as the manual says to do and it remained like that.
              It also freezes in these service menus because I was cycling through the options and all of a sudden it got stuck, so it's most definitely not a power issue I'd say.
              Wattevah...
              • R_J
                • Jun 2012
                • 9550
                After it locked up while cycling through the menu's did you re-check if there were any errors in the log again? ie DC: xxx or OL: xxx
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  I briefly mentioned this, though I admit not very clearly, in my previous post - no, it doesn't register anything even when it power cycles: still 000 all around.
                  Wattevah...
                  • madan1
                    • Nov 2016
                    • 682
                    Check if the dsp, cpu, ram, rom etc ICs have good power supply.
                    by the way it is very good that all components remeber their versions.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      I tried a firmware upload via USB provided by someone on a local forum and it shuts off during the install. Thankfully it didn't brick it, but didn't solve the issue either. Still no errors recorded.
                      Wattevah...
                      • Drack
                        Yup it's me
                        • Nov 2016
                        • 297
                        • Venezuela
                        If you have a thermocouple it would be good to check the temperature of all the ic's and heatsinks and report them here.
                        Also you should check voltages when it's working and when it locks up to see if there is any difference.
                        Drack.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          Yes I do have a thermocouple but I've returned the unit long ago. Nothing seemed to get abnormally hot to the touch though. Forgot to update the post, but after doing some digging it turns out this is a common fault with this units and it only gets worse to the point where the firmware displays 0000 or something like that. They're not repairable though, so the only solution is a board swap, at least not repairable for us average-joes who lack the hardware and software solutions.
                          Wattevah...
                          • Drack
                            Yup it's me
                            • Nov 2016
                            • 297
                            • Venezuela
                            Oh okay, sad to hear that it's not repairable.
                            • RatherLoopy
                              Pioneer VSX-44 receiver HDMI dropouts
                              by RatherLoopy
                              I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                              I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                              And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                              05-26-2023, 03:54 PM
                            • pulper111
                              Pioneer VSX-1123 Receiver - weird voltage problem
                              by pulper111
                              Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                              I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                              09-02-2020, 11:12 AM
                            • thetonywarren
                              Pioneer VSX-3300 Receiver Wont Power On
                              by thetonywarren
                              Have a colleagues Pioneer VSX-3300, it wont power on, hasnt for a number of years, but just now trying to figure out what's going on with it.
                              It has 120V input and I have followed that 120V to a small board that appears to have a small transformer and a relay among a few other components I dont think the relay is changing state which I believe turns on the receiver, but this is all speculation.....
                              I have downloaded the repair guide, which I have attached to this post, but I am having a hard time following it.... Can someone please offer any advice on what to check?...
                              12-28-2021, 01:26 PM
                            • wolf1976
                              wireless receiver for 6 speeds fan control with remote control
                              by wolf1976
                              hi i have a receiver that is destroyed from the overvoltage i guess
                              my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                              the motor fan has not label
                              i have an other receiver operational
                              In your opinion can i measure the voltage at the output ?
                              what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                              thanks in advance...
                              07-23-2025, 03:12 PM
                            • CdDvdFlash
                              DSE GE6878 possible TV receiver dying remote not working well
                              by CdDvdFlash
                              For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                              07-03-2024, 03:55 AM
