can anyone explain how this protect circuit operates ?
  • petehall347
    • Jan 2015
    • 4448
    its in a samick smp-4000 ..its driving me nuts .. 3 resistors lifted and q117 still affects drivers bases when i freeze it .. cant get it bias .. positive to negative swings with heat and cold ... am missing something obvious here .i am going to pull r159 to see what happens ..if that dont work ic101 is going . ... its very odd as good channel only works with bad channel removed although bias is still ok on that channel ... https://elektrotanya.com/samick_smp-.../download.html
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    Re: can anyone explain how this protect circuit operates ?
    Does Q117 actually have anything to do with bias? Or is it just for driving the protection LED?
    -David VanHorn
    • petehall347
      • Jan 2015
      • 4448
      thats what i am trying to figure out .. it certainty affects those driver base voltages when i freeze it
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        Well... from what I can make out from it:
        The output from the protection IC, IC101 provides feedback to Q120 via R108(?), and by extension, Q101/Q102. That seems logical enough. Normally that IC101 (TA7317P) is designed to switch a speaker output relay, but they seem to be using it to switch off Q120 and thus cut power to Q101/Q102 in the event of a fault instead. So it would seem that this would effectively disconnect the audio input signal to the amplifier, and that's about it.
        That output from IC101 also drives Q117 through the voltage divider of R159 and R160, lighting the protection LED (LED 2) if there is a fault.
        I'm thinking that C123 is probably used to prevent LED 2 from flickering, and Q118 simply used to provide a faster way to discharge C123, but keeping the discharge current low enough that in an actual fault condition, LED 2 will still be able to light. Seems a bit overcomplicated but that's all I can think of as to its purpose.
        The next stage of that circuit with C124, Q119, I think may only come into play at switch on\off, as it has a larger capacitor, and probably again, to prevent some spurious LED 2 output at power up or power down.
        I really see no way that Q117 could affect the actual amplifier stage, unless you're accidentally freezing\heating IC101 and\or one of its support components.
        -David VanHorn
        • petehall347
          • Jan 2015
          • 4448
          at present i have r142 and r155 lifted and cooling and heating isnt changing voltages at the drivers bases like it was before .so at least its now stable but no bias drive .. i went over all resistors in circuit and transistors and nothing jumped out as yet .
          • petehall347
            • Jan 2015
            • 4448
            case closed for now .. found broken trace by q107 collector .previous work is shoddy .. bias will turn up now . still work to do yet but it looks like its going to work ..
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • M1NEBLANK SHOW
              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
              by M1NEBLANK SHOW
              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
              Schematic and Boardview here
              04-04-2025, 03:57 PM
